![]() | Home > Maintenance & Mods (L322) > Revisiting the throttle elbow seal on the 4.4TDv8 |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3381 ![]() ![]() ![]() |
After doing the O ring mod last year I'd noticed it was still leaking so after taking it apart and measuring everything I'm not convinced the O ring mod is a fix. The 'nose' of the TB housing is 81mm dia and the inner dia of the elbow is 90mm so it idealy needs O rings 80mm inside dia and 5mm thick to seal between the TB nose and plastic elbow. Something like this may work
I adjusted the retainer and it fits fine - a bit fiddly but if you do itwith the elbow off the car you can see when it's right as all the ends stick through the slots evenly. If you are worrid about this comming off it would be easy to put a large zip tie or compression clamp around it. 2012 TDV8 Vogue (L322) |
This should fix it.....
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1357 ![]() ![]() ![]() |
Blimey, I know the hose is expensive at £217, but don't you think it's time to admit defeat and just buy the proper part? Considering the price of other parts for our cars it's not the most expensive of items.
As I said the bigger O rings at <£7 would probably do the job just as well as long as you can seal the sealing ring retaining holes but as I'd bought the coupler I thought I'd fit it anyway. Also the standard seal is not very effective and as mine has a damaged TB 'nose' it would not seal properly anyway. 2012 TDV8 Vogue (L322) |
Should have waited until the T bolt hose clip arrived.........
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 238 ![]() ![]() ![]() |
I replaced mine with a new genuine hose back in February, was £207 but if it lasts as long as the original did then it’s worth doing it properly. Also I’m not worrying about it leaking with a diy fix. |
