![]() | Home > Technical (L322) > 4.4 TDV8 Serpentine Belt Replacement |
Benji1 Member Since: 11 Sep 2023 Location: Perth Posts: 36 ![]() ![]() |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2748 ![]() ![]() |
Item 11 is the tensioner pulley. Put a socket on the hex nut cast as part of the tensioner housing, rotating it clockwise to allow the back of the belt to be slipped off/on the smooth pulley 9. You will need an extension on the socket handle to get enough leverage to pull and hold against the spring in the tensioner.
Thanks Graeme.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3332 ![]() ![]() ![]() |
Traditionaly replacing the belt involves removing the fan and shroud to get enough access. If it's slipped off so easily it may also point to wear in the tensioner. 2012 TDV8 Vogue (L322) |
Thanks JayGee,
