Home > Technical (L405) > Deployable side steps switched off
Mikeinatruck
United Kingdom 2018 Range Rover Autobiography SDV6 Santorini Black
My side steps appear to be non responsive, they are showing as off on the display but when you switch them on they go back to off straight away.
One is out and one is in.
Dealer had it for a service and it was all fine when it went in but there was no one in service in Saturday when I collected it so had to take it.
Is there any way to switch it on without a dealer plug in? 2018 L405 Autobiograpghy
Post #692959 19th May 2024 12:07pm
i'm sure theres something in these threads that will solve your problem,
https://www.fullfatrr.com/forum/search.php...rch_time=0 ... - .- -.
Post #692970 19th May 2024 3:24pm
Mikeinatruck
I have looked through a lot of those but nothing relates to a 2018, only thing of interest was the tr2 knob was referred too... What's that? 2018 L405 Autobiograpghy
Post #692972 19th May 2024 3:49pm
That's the Terrain Response dial - next to the gear selector - it should be down - when you press it, it pops up.
On mine, IIRC, there's a steps button by the drivers right knee, above or below the boot open button. Holding that in whilst you switch on the ignition turns the steps on & off
Post #692978 19th May 2024 4:32pm
Here's the manual -
Post #692979 19th May 2024 4:37pm
Mikeinatruck
Oh right of course... mines down... Mine is a 2018 so I dont have the button by my knee, on my main display I can turn them off/on set roof access or off road mode, problem I have is they are switched off and when I press on, it goes off after 2 seconds and wont stay on, no fault codes logged.
I cant manually deploy with my diagnostic either, says ECU unreachable that makes me think its been turned off like delivery mode... 2018 L405 Autobiograpghy
Post #692982 19th May 2024 5:02pm
ECU unreachable sounds like either a faulty steps ECU, a loose connector or a broken wire in a loom somewhere.... I wouldn't really know where to start Confused
Post #692984 19th May 2024 5:26pm
I've not watched it, but this guy has done an installation video, so I guess that will show you where the wiring goes, so that you can at least check the connections ?
Post #692985 19th May 2024 5:30pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
He has the early model 2016 onwards, which are different the modules are on the left side of the spare wheel as opposed to the right side in the early ones, and there is also no control button on the lower dash
the later models are only controlled from the dash in format system Big Cry
It could be a fuse in the rear right side of the boot area check in your owner's manual.
otherwise, it could be a stuck motor or damage to the brackets. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #692998 19th May 2024 7:30pm
Mikeinatruck
Fuse was ok, I spoke to the dealer as it happened when they had it in for a service, they are collecting it and taking it back in to sort it as it's their fault.
My diagnostic reader says ECU unreachable see so I think they have in initialized it and it's gone off line. I'll report back once they resolve it, at least it's not costing me money, well diesel for the two hour trip back to the dealer but hey ho... 2018 L405 Autobiograpghy
Post #693045 20th May 2024 11:06pm
Almost certainly not relevant to this situation but FWIW
I always set my steps on roof access when I clean the car (in the screen option) and the steps pop out. Once the car's done I switch roof access off and the steps stow away. On a minority of occasions, about 30% of the time, they then won't operate, just stay permenantly stowed. I've tried various ways to get them active again and the one that always works is to press the Terrain Response dial so that it raises, and then just push it down again. The steps then work normally again. Mike - MPx
Post #693054 21st May 2024 10:27am
M11buc
United Kingdom 2019 Range Rover Autobiography SDV8 Santorini Black
Just a thought. Did the dealers do any kind of software update or reset ( maybe had the key security update ) if so if they reset the ccf files. It knocks off the side steps. If so easy fix to switch back on again. Hopefully dealer will help and sort.
Post #693423 27th May 2024 11:34am
Mikeinatruck
It went back to the dealer and when they sorted the steering column calibration they lost the connection to the side steps ECU. All sorted now after they turned it back on. They even put some fuel in the tank for me.. 2018 L405 Autobiograpghy
Post #693424 27th May 2024 11:39am
noone
United States
Can you elaborate further on what the dealer did to restore the connection to the DSCM? (Deployable side steps controls module)
I’m having the same issue on my 2019 I just picked up and it was like this when I got it. I even bought a new DSCM and plugged it in and both steps deployed out and are still out so I know the motors and hinges are fine. I go into the screen and press the power button and then it turns back off in 2 seconds, just like it did prior to me plugging in the new module. 2023 L460 Range Rover SE P400
2019 L405 Range Rover ATB LWB
Post #721415 16th Jul 2025 6:43pm
noone
United States
What diagnostic reader were you using and what is the name of the ECU that indicated unreachable? Thx in advance. 2023 L460 Range Rover SE P400
Post #721737 22nd Jul 2025 8:40pm
