Home > Technical (L405) > L405 SDV8 Oil in the plenum etc. Help!
Neil183
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Hi everyone.
Had the dreaded restricted performance message appear on my well maintained 2013 144k mile SDV8 L405, just as I was about to prepare it to sell - typical!
Checked the code and reading P006A-00, removed sensors, cleaned, replaced ran OK until second turbo kicks in, then same limp mode.
Ended up removing plenum, throttle body, EGR pipe etc as they were caked in heavy soot/oil - very nasty...
Anyway put back together nice and clean, cleared codes, drove 2 miles, but exactly same problem.
Investigated again and the throttle body/sensor etc had a fresh layer of oil over the insides. Sad
Any suggestions as to where this oil may be coming from please as im sure this must be the problem??
Much appreciated.
Thankyou
Neil.
Post #693067 21st May 2024 4:59pm
kevinp
Have you just changed the oil filter by any chance?
Post #693074 21st May 2024 6:24pm
Neil183
No, but it had a service not that long ago, probably done 1000 miles since.
Is this relevant maybe?
Post #693075 21st May 2024 6:35pm
kevinp
There is a chance that the oil filter drain valve may have come off it's post underneath the filter. Worth taking the filter out and having a look. Thumbs Up
Post #693079 21st May 2024 8:16pm
Good shout Kevin... was just about to chirp in the same advice... Thumbs Up
Post #693098 22nd May 2024 12:43am
D3Jon
Interesting... How does this lead to excessive oil getting into the throttle body / intake pipework, etc? New one on me? <<--- BTW, this is a genuine question! Thumbs Up
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #693105 22nd May 2024 9:11am
kevinp
I don't realy know to be honest. Someone on here did explain what happens if it's misplaced.
My car started using a lot of oil and smoking out the exhaust. It was diagnosed as needing 2 new turbo's at about £7000.
I found mine had come off it's post. After refitting it has not used a drop of oil since and no more smoke and I still have £7000.
What I did notice before finding the problem was that the MAP sensor was soaking wet instead of dry and powdery. Thumbs Up
Post #693149 22nd May 2024 9:29pm
D3Jon
Thanks Kevin, Thumbs Up
Will do a search for that post, as I'd love to know how incorrect oil filter installation leads to oil getting into the intake system? I'm speculating it's via a breather if the top of the engine is filling up with oil?
I wonder how many people have shed out an awful lot of money on unnecessary repairs, when the fix may be as simple as the oil filter not being seated correctly on its post?
2014 Disco 4 HSE
Post #693166 23rd May 2024 9:30am
caymanblack
Bloody hell who diagnosed that Kevin? Censored overfinch modified
Post #693168 23rd May 2024 9:33am
kevinp
It's not that the oil filter is not correctly installed, it's the drain back valve that comes off it's locating post.
Post #693171 23rd May 2024 10:28am
kevinp
To be fair the car gave all the symptoms of blown turbo's.
I discovered the problem of the valve becoming detatched and nobody seems to have mentioned before that this can happen.
That's why I say to always check it is firmly in place before installing a new filter.
Post #693180 23rd May 2024 12:48pm
D3Jon
Gotcha! So that being dislodged, would lead to the oil filter housing draining down when the engine stopped, leading to a slightly longer time to get oil pressure when starting the engine.
Not bunging up the housing drain hole must cause an excess of oil somewhere else (when the engine is running), where it must then find its way into the intake system; via possibly a crankcase vent?
Rover V8's used to have this problem (especially on track with lateral G's), where the oil couldn't get back from the heads to the sump quickly enough, leading to it going out through the breather system and being ingested into the intake system. I got black flagged at Mallory Park for this very reason, with a smoke screen behind me, James Bond style! Made a temporary oil catch tank out of a thermos flask and back out for the next session!
2014 Disco 4 HSE
Post #693181 23rd May 2024 1:52pm
Neil183
Turns out that the plenum had split along the seam slightly causing an air leak. Not sure if this was there before or if I damaged it cleaning to be honest...
I thought I was clever, opened up the seam a bit with a Dremel, cleaned and filled with epoxy plastic padding which I used before with great success as it goes rock solid. Alas, twas not to be, within 5 minutes it had blown apart again so I now definitely need a new one.
Looking around they seem to be £600-£700 unless anybody has another solution maybe??
Cheers
Neil.
Post #694256 11th Jun 2024 3:01pm
JayGee
Chain rivet the seam with pop rivets or self tapping screws. The turbo hits just under 1.5bar above atmospheric so quite a lot of pressure.
 2012 TDV8 Vogue (L322)
Post #694258 11th Jun 2024 3:27pm
Neil183
Blimey, thats very inventive!!
Post #694271 11th Jun 2024 7:32pm
