Home > Technical (L322) > Towing electrics help needed please
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
So after my disastrous encounter with MRDS Ltd I’ve now found yet another issue with my car, I’ve got plug and play towing electrics 13pin socket that was working perfectly when it was taken away as towed my tin tent a few days before it was collected, I went to pick a new trailer up and nothing works we tested a brand new board and still nothing, I checked the car and 13 pin towing is enabled, the plug in the boot is fine the 13pin plug is also ok, the fuses and relay in the boot are fine, in the passenger fuse box fuse f27 a 10amp fuse was blown so I replaced this and checked and there is power to both pins, same for fuse f48 but fuse f11 there is no power to either of the pins when ignition is on so I’m assuming this is an issue but not sure why nothing at all works on the tow wiring bloody fuming.
Hoping someone can help we’re away in the tin tent Friday 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #693078 21st May 2024 8:11pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Can you check that the earthed pins on the car socket are in fact connected to earth? Most towing light connections are caused by faulty earths on either the car or trailer 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #693088 21st May 2024 9:39pm
Furnitureman
Hi V8 Bob good shout I’ll check tonight I have one of those plug in testers the permanent live is there but nothing else I’ll check the earths tonight, it was working perfectly before it went away now nothing 2012 Range Rover Westminster 4.4 TDV8
Post #693100 22nd May 2024 5:44am
