Home > Technical (L322) > Issues ?
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Issues ?
Hi all,
My Deployable side steps stopped working after a flat battery
And ideas ?
Post #693381 26th May 2024 7:46pm
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
In the search you will find a few posts about how to reactivate from the switch near the sunroof. From Memory its holding the swith and turning the car on and off.
Mine also stopped working but it turned out to be water ingress in the motors which coinsided with a flat battery.
This topic is fairly heavily covered so try a few searches if you can Current yokes
2012 4.4 TDV8 Westminster
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #693478 28th May 2024 11:39am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Mine also weirdly jammed half out, I resolved it by removing and refitting the fuse a few times with the ignition on, each time I did it it jumped a bit.
Eventually on the 5th or 6th cycle it went the full distance and has worked fine ever since, in my 2012 Westie it was fuse 58. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #693480 28th May 2024 12:38pm
