![]() | Home > In Car Electronics (L322) > mp3 discs |
you will find if you have a 2006 onwards to be safe..the cd player should support mp3's, just drag them to the disc dont make any files or it wont see them. V8 facelift Range Rover Autobiography 22" wheels.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
MP3 discs work on all touch screen systems, you can see those in 54 plate cars too.
Avi Member Since: 24 Sep 2010 Location: North West Posts: 309 ![]() ![]() |
It will only read one folder deep on Mine (MY2006 with touch screen)
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
So instead of using something like pinnicale instant to copy i can just 'drag and drop' ?. They are audio cd's so somehow i have to convert them to mp3. Once converted can i drag and drop as album1 tracks1-10, album2 tracks1-10 etc etc or do i need a root file.
david sent you a pm V8 facelift Range Rover Autobiography 22" wheels.
I used Roxio and Nero to create a data disc and yes, just drag and drop till the disc is full.
good point RRUK and stick to good branded cdr, i always go for tdk. V8 facelift Range Rover Autobiography 22" wheels.
fe600 Member Since: 02 Jun 2010 Location: World Posts: 13 ![]() ![]() |
You can put up to 20 folders on the disc.
fe600. Many thanks indeed for your comments. |
trafpol Member Since: 15 Jun 2011 Location: Surrey Posts: 141 ![]() ![]() ![]() |
If you have access to Gracenote to automatically label everything then burn with Nero - preferably Nero Express - you get perfect results . Nero will also convert to Mp3 from other formats for you. If you have a lightscribe burner you can put a label on as it prints direct on the disc. Under no circumstances use a paper label - do you fancy having to remove the whole unit if it comes off and jams everything......? |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
If you have itunes the files purchased form the store are not compatible with the system. You need to convert them to MP3 which iTunes can do for you surprisingly easily.... |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
I can confirm fe600s comments, I initially burnt a cd with around 280 tracks in the root and could not read past around 50, so , as they were just a mix of tracks, I created folders called A-D E-H I-L etc and put the artists under their relevant folder associated with their name, then was OK. Steve
just0007 Member Since: 12 Sep 2010 Location: london Posts: 56 ![]() ![]() ![]() |
Sorry I know I am being stupid but I have tried numerous times, how do I get my tunes from my I tunes to range rover so tracks are displayed on the screen. Please help I have tried to convert to mp3 clicking the box in I tunes only to get problem box appear . |
To convert files bought from the iTunes store to MP3 (I don't know if this will work with older files that have full DRM on them, but give it a try, it can't hurt...) go to your preferences and select the import preferences to be MP3.
