![]() | Home > Technical (L322) > L322 3.6 TDV8 - Engine System Fault |
Mads Member Since: 18 Oct 2020 Location: Lommedalen Posts: 16 ![]() ![]() ![]() |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3307 ![]() ![]() ![]() |
Crash sensor active? - this sounds like a sytem to stop the engine running after a collision so there must be some way to reset it. 2012 TDV8 Vogue (L322) |
That was my thought as well. The battery were not tightend sonit could move a bit inside the battery-room (?). All tho I can read the same fault on my other L322 TDV8 which runs great.
Did some more checks this morning. It throws B10A2-36 fault which is related to the «crash inertia faul» according to TOPix. All tho the problem is that its pretty much impossible to find the switch. If the car has one. TOPix says its between the ECM and RCM which makes sence, but where the heck is the switch?
Ok. Got some more time to do re-search on the car in question.
Have done some more reaserch on this matter.
Another update to this matter.
Another update.
KangaBen Member Since: 06 Nov 2024 Location: Melbourne Posts: 1 ![]() ![]() ![]() |
Hi Mads, did all of this fix your issue? |
MarkNL Member Since: 26 Jan 2014 Location: utrecht Posts: 44 ![]() ![]() ![]() |
