Home > My Range Rover > 2012 Vogue TDV8
Page 3 of 11 <123 4 ... 91011>
toby1
After fitting the weatherseal the sill plate would not go back, but it's had it anyway. I presume this is illuminated if it was working?
Post #693922 5th Jun 2024 2:42pm
toby1
A win and a fail.
New air filters fitted: From left to right > RH; LH; new.
Depending on useage I reckon one could replace the LH filter at twice the mileage of the RH.
I must be missing something as I could not fit this RHF bumper deflector, despite ordering the correct plastic nut. The fitting is hidden on the LHF but I think there must be a screw required
Post #693977 6th Jun 2024 2:01pm
toby1
I think I have fixed the door, fingers crossed. I RTFM more closely and I noticed a missing grommet where the three screws are that hold the latch. A peep in there is a 4mm Allen screw. I turned it fully clockwise and now the door reliably opens. The manual says wind it two turns but that does not open the door.
Coupled with the new weatherseal, the door has a more pleasing action. I need a new grommet though.
A test drive yesterday reveals a loud viscous fan and possible coolant loss. More research required.
Post #693996 6th Jun 2024 6:38pm
toby1
The new rear lamp screws are much better and I sourced a decent used LH rear lamp. I decided against the Chinese eBay ones as I could not find a review on them, good or bad.
If I can find any enthusiasm I may put one of the old lamps in the oven and see if that softens the glue enough to remove the lens.
Post #694261 11th Jun 2024 4:56pm
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
Watching this thread with great interest. You’re a brave man and hats off to you for tackling so many jobs which is enjoyable to follow. Good luck and keep up the good work. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #694283 12th Jun 2024 3:41am
toby1
The real fun/pain will start once I start poking about the underside Smile
Post #694298 12th Jun 2024 10:43am
toby1
Oil change done today at 155,088 miles, though I made a meal of an easy job. My £10 Lidl oil pump would not suck a drop but I may have blundered by hooking it up to the vacuum hand pump tank and that may have been too air tight for it - not sure. Anyway, two pumps by hand and away it started. I used the same pump as Sam's M&M. 9.5 litres out/in - I had to empty the tank as it was full at 9 litres.
Costs are (everything from eBay bar the Lidl pump):
Nielsen hand pump £48
Oil from S&A £85 (enough for two changes)
Mann oil filter £16 IIRC
Lidl pump £10
36mm socket £5-ish
Pump ran OK but not a drop sucked. May be my fault though.
Hand action worked fine
Post #694500 15th Jun 2024 4:54pm
toby1
I checked the oil level this morning and it's one notch below maximum so all good. I reset the service required message after finding the two pedal process.
It's definitely losing coolant though, another 0.75l to top up.
Post #694547 16th Jun 2024 2:37pm
toby1
The coolant bottle is nearly empty after driving around 80 miles to/from work this week. I've bought an oil analysis from Oil Labs so I'll send it off later and should have a report next week.
Post #694833 21st Jun 2024 1:40pm
JayGee
Have a look down under teh intake donut into the V where the oil cooler and under it the EGR cooler sits. This is where mine is loosing coolant but at a slower rate than yours. There are also examples where some of the push fittings for the coolant system are leaking due to failed O rings so that's work looking at as well. You can buy cheap USB endoscopes / borescopes to look in these tight spaces without having to remove stuff. 2012 TDV8 Vogue (L322)
Post #694841 21st Jun 2024 4:44pm
toby1
Thanks JG and agreed. I have some intake work to do soon. I am thinking 4 x doughnut intake hoses, plus oil cooler gaskets/seals.
I have the oil cooler O rings and 3 x intake O rings (see Sam's M&M) but not the lower gasket seal yet.
As long as the oil report doesn't mean an offload to WBAC then I will carry out the work next month.
Post #694861 21st Jun 2024 9:20pm
toby1
The oil report is in. I am not sure what to make of it just yet but this was for 10,000 miles.
Post #695253 29th Jun 2024 10:59am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
If I'm reading this correctly you don't seem to have a water ingress problem as the sodium levels are way below what would indicate a problem.
Silicon levels suggest a possible air intake leak, so best look intp that, but it's not excessive.
You'd expect to have some fuel dilution but it's not calling it out as excessive.
However, your iron levels are higher than the recommended expected max so warrants further invest.
But it doesn't say how old the oil needs to be before these figures apply to, i.e. is this for oil that's done 1000 miles or 10,000.
When I worked on choppers we tested the oil daily, or every 5 hours running time and monitored the difference, this doesn't seem to have a comparison reference. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #695275 29th Jun 2024 8:45pm
JayGee
Change the oil and test again at the next service at the 5-7k interval most owners have settled on for higher mileage engines. Oil dilution and viscosity loss increase in rate as the DPF capacity declines from ash loading meaning shorter regeneration intervals. 2012 TDV8 Vogue (L322)
Post #695279 29th Jun 2024 9:54pm
toby1
Yes, I think that is the next thing to do. Also, I think I'll undo the sump plug after suction to make sure it's empty of oil.
Right. I am off to a vilage car show near me, then a DPF run on the M4 then watch the F1.
Post #695284 30th Jun 2024 10:11am
