Home > Technical (L322) > Rear Shocks
Jimdonut
2012 Range Rover Vogue 4.4 V8 Zambezi Silver
Rear Shocks
One of rear shocks has just splurged its oil on the driveway its a 2012 model so looking on the web theres a few options i take it i need the ones with the vds
There seems to be a few options available! Is this pretty easy to do myself?
Post #694126 9th Jun 2024 3:28pm
JayGee
Easy DIY joib. Get the Bilstein ( OE) and do both sides not just one. 2012 TDV8 Vogue (L322)
Post #694128 9th Jun 2024 4:34pm
mjdronfield
I got mine from Island 4x4. Decent price.
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #694141 9th Jun 2024 6:26pm
Jimdonut
Thanks ill order this and try fit them!
Post #694184 10th Jun 2024 9:50am
JayGee
Got mine from there as well. There's a thin gasket that goes on the top which you can reuse from the existing shock if you carefully remove it but I didn't fit it on mine Embarassed 2012 TDV8 Vogue (L322)
Post #694187 10th Jun 2024 10:50am
Jimdonut
Thanks ,do they have an electronic connection on them ? Does anything have to be reset
Post #694192 10th Jun 2024 11:51am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
Just out of interest, what front shocks do you recommend pairing with these Bistein CVDs Rears ?
I've tried on their website and I can find normal shocks but can't see the 2010 to 1012 CVD version.
Both Island 4x4 and Bilsteins, anyone have a part number ? Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #694193 10th Jun 2024 12:27pm
JayGee
Plug on the top just a push fit. Nothing else to adjust but do the final torque of the lower long bolt with the wheels on the ground. 2012 TDV8 Vogue (L322)
Post #694196 10th Jun 2024 12:45pm
JayGee
AndyRoo wrote:
Hi,
Front OE shocks were BWI not Bilstein. I went with Aerosus at the fronts as I was replacing the whole lot but the shocks were not realy worn so unless they are obviosly not functioning properly and the front end is wallowing about maybe leave alone or just change the bags? 2012 TDV8 Vogue (L322)
Post #694197 10th Jun 2024 12:48pm
GraemeS
Australia
I fitted Bilstein CVDs to both the front and the rear but had to replace new Bilstein rear springs with genuine after they were ripped apart because they were too short for off-road usage.
Post #694199 10th Jun 2024 1:15pm
AndyRoo
Ok, thanks for that feedback, I don't need yet but good to know. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #694215 10th Jun 2024 4:23pm
