![]() | Home > Technical (L405) > "Steering Column Locked" - intermittent problem |
SJ1971 Member Since: 21 Apr 2025 Location: Essex Posts: 3 ![]() ![]() ![]() |
Did you ever get to the bottom of this, I saw you had no replies despite a well constructed post. I've just bought a used 2016 L405 and this message just popped up after owning it since Good Friday now Easter Monday, should I return it as a big issue to the used car dealer I bought it from or did you find an easy fix? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1522 ![]() ![]() |
Could it be possible that the solenoid in the lock mechanism is starting to fail / not actuating as well as it should ?
IanLWarr Member Since: 09 Jun 2024 Location: North West Posts: 5 ![]() ![]() ![]() |
Hi fisha/SJ1971 ... a bit of a long story ... but, hope it helps ...
Interesting ... so its a motor rather than solenoid. I guess its possible that an old one just starts to fade and not work, or teeth get stripped, or just needs a clean etc etc. V8 or else ... |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 149 ![]() ![]() ![]() |
Great post, Ian. Glad you’ve got it sorted. |
Thank you for the kind words - looks like I’m writing a book!
That’s what we were thinking - nothing obvious though and no way to test it. I have the remains of the donor steering column (and old motor) if anyone wants it. Looks like it could have come out of a scalextric car!!! ![]() |
Thanks for such a detailed reply Ian, you've definitely persevered, it only happened to me this afternoon once but after wiggling the steering wheel it cleared the fault so perhaps it was just caught and needed a wiggle. I had a 14 plate L494 RRS before this one for the past 5 years and never had this problem and that one had 125k miles on it, this one only has 61k on a 16 plate.
It does look like you can order a replacement motor from good old eBay:
Hi,
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1828 ![]() ![]() ![]() |
That looks like a Mabuchi motor, as used in high-end Nakamichi cassette decks, but I can’t say which model |
