Home > Maintenance & Mods (L322) > Westfalia Tow Bar Lock
StephenO
Scotland 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Wondering if anyone has changed a lock on a Westfalia tow bar.
Looks like the previous owner has welded the key lock to prevent theft. I don’t tow but would like the option too just in case. I’ve seen a video on here how to knock out the lock but wondering if it’s just a matter of replacing the lock. I’d rather the tow bar was stored in the boot and used when required.
Please see photos of my issue, any help would be much appreciated.
Cheers
2015 Land Rover Discovery Sport
Previous
2016 Range Rover Sport Autobiography
2007 Land Rover Defender 90
2005 Land Rover Discovery 3
1994 Land Rover Defender 90
1968 Land Rover Series 2a
Post #694327 12th Jun 2024 7:41pm
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
I suppose there's nothing but getting it drilled out or such.
See if a locksmith is able to help you out once it's off.
Otherwise find one with keys on Ebay or such.
Post #694386 13th Jun 2024 7:47pm
StephenO
Yeh they can be tapped out from the opposite side of the lock with a bit of force. I was wondering if anyone had actually done it and changed the lock with success. Cheers 2012 Range Rover Westminster
Previous
Post #694391 13th Jun 2024 8:35pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
I did a lock replacement on a ceased swan neck some months back. I was not able to find a direct lock replacement. The only replacement barrel & keys I could find had an armature that was too short. I fitted this anyway to keep the grime out of the release mechanism.
Scant information on line about the best way to do this. The best technique I found was here ( how’s your Swedish ? )
https://youtu.be/UTm8xsr7ZYg?si=W-YVr0al9V2kzVp9
My swan neck was off the car but I think this could be done in situ with some care.
Once the lock is out you can move the release mechanism to lube it and drop out the swan neck. If it’s been in the receiver for a while it may need some persuasion.
On the bottom of the swan neck there is a lubrication hole. This is usually clogged with dirt but once cleaned out it allows the internal release rod to be lubed.
One thing to note; on the top of the swan neck there is a plastic cap with a hex socket. Best to leave this intact. It looks like it can be removed but in practice removing it destroys it and replacements are not available as far as I know. Without this cap in place dirt will ingress and progressively fowl up the swan neck locking ball bearings causing it to cease into the receiver. Luckily I learned this before hand.
If anyone knows the correct part number for the barrel & keys please could you post on here. TDV8 4.4 2012
Post #694651 18th Jun 2024 4:38pm
Ramblin Man
I recall that this can only be done without damaging the internals once the lock barrel has been removed. Once the lock barrel is out there is no real need to remove release knob as it should move freely to release the swan neck. TDV8 4.4 2012
Post #694654 18th Jun 2024 4:45pm
Seems slightly pointless..... what have they done about the single nut & bolt that holds it into the square receiver ?
It won't be as easy to store, but that bolt can be replaced by a pin allowing the whole assembly to be removed & stored.
Post #694659 18th Jun 2024 6:15pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
With my amateur welder eyes that doesn't look to be welded. There is no spot and no disc or grinder action. It looks more old, disused and crusted to me. Have you tried cleaning it up with a mild acid and polishes? I have found over years fine road dust can set like pretty much like cement.
Post #694670 18th Jun 2024 8:17pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
You might also find that the tow bar swan neck has rusted and seized in the receiver. It looks a bit rusty and if the previous owner intended to keep it there, it is unlikely they applied any grease before inserting the neck to the receiver. There are usually towbar listed on eBay. There is a hitch advertised on Gumtree at the minute but it is located in Belfast and priced at £180 which I think is pricey even though it looks new
I must stress that I am in no way connected with the seller.
. I hope you get sorted.
Please view this ad:
Range Rover De-tachable Towbar,
https://www.gumtree.com/p/cars-vans-motorb...1471657072
Price: £ 180
Download the application from the Google Play Store.
https://play.google.com/store/apps/details?id=com.gumtree.android
Post #694742 19th Jun 2024 10:58pm
Remove the whole lot - swan neck and the receiver.
Soak it - for days (as in washing up bowl/bucket) full of your preferred easing fluid - petrol/diesel/other...).
Give it a good clean up to then see what you have got ( I agree that it does not look to be welded)
I presume you do not have a key for it ? Is it locked ?
If not locked, use any manner of persuasion to see if you can release the swan neck from the receiver. .
Post #694745 19th Jun 2024 11:11pm
toby1
This is mine. It took a bit of effort to undo the 24mm nut/bolt. I have no idea if this is useable or saveable. I do not have a key if one was issued.
Post #694750 20th Jun 2024 11:09am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
It's probably the key snapped off in the lock, any self respecting locksmith or yourself with a fine bradawl should be able to poke that out in no time, it doesn't look corroded in either.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #694760 20th Jun 2024 1:04pm
