![]() | Home > Maintenance & Mods (L322) > A Solution for my swollen nuts ........:-) |
essex boy Member Since: 21 Jan 2017 Location: essex Posts: 214 ![]() ![]() ![]() |
Cream ice cubes and loose underwear |
Ian Donkin Member Since: 17 Aug 2010 Location: A Yorkshireman in Surrey Posts: 107 ![]() ![]() |
Excellent tip!
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 406 ![]() ![]() ![]() |
Advanced Factors in the end - hopefully will prove good enough quality to out last the car (or me)!!
Proftinkerpot Member Since: 23 Dec 2022 Location: County Antrim Posts: 202 ![]() ![]() ![]() |
Could you not have fitted a bigger socket over your swollen nuts?
I had a back up plan;
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8789 ![]() ![]() ![]() |
A few places now selling them....
Yes indeed, on this occasion Amazon was cheaper. Although using my recycled method it’s a free fix!!
If your nuts are perfectly normal then what more do you want.... |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
I treated mine to some stainless steel ones from a member off the forum. Expensive but nice. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3324 ![]() ![]() ![]() |
I just have a 23mm socket for the few that are too tight for the 22mm. 2012 TDV8 Vogue (L322) |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 690 ![]() ![]() ![]() |
I used 7/8 imperial socket on mine just loose enough without being too loose, sockets are not really a precise tool, so a 22mm from a cheap set might well fit.
All good solutions to the problem. On the day I had run out of options, didn’t have a 23mm socket, nothing else big enough other than a 24mm I’d bought when fitting the tow bar.
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 262 ![]() ![]() ![]() |
I spray my nuts weekly with WD40, keeps the swelling at bay. 2011MY 4.4TDV8 Autobiography Baltic Blue
