Home > Technical (L322) > AIR. SUSP. INACTIVE/HDC INACTIVE
invisible999
United States 2005 Range Rover HSE 4.4 V8 Chawton White
I drove off from a parking lot for about 30 seconds and at the exit comes audible sound and the message AIR. SUSP. INACTIVE and HDC INACTIVE with yellow exclamation mark on dashboards.
Ignition on/off, driving for 30 min off, then on - did not help. So it has been like that for last couple of days.
I replaced front struts (shipped from Island 4x4) and height sensors just two months ago ($2700 spent on it). What can I do to troubleshoot the problem and resolve it? Fuzes, etc? Else?
I also have ALL COMMS III cable with software and just got used/replacement BCU from Ebay. Should I try to swap the BCU (disconnect battery first), reset settings of BCU after connection and see if it fixes the problem?
If not, what else? Looking for collective wisdom here.
P.S. 2005 RR HSE. Bought for $7500 2 years ago. Spent $10K on repairs.
P.P.S. The most exensive car is a cheap British car....
Post #696008 11th Jul 2024 6:52pm
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
Chasing similar issues myself for months, my diagnostic told me the issue was the front left height sensor but having replaced it noted both the rear sensors were shot so could be something completely different... helpful in know but don't just blindly follow the diagnostic.
My HDC warning tends to show up if the battery is a bit low so worth checking that and the terminals
Also with regards to suspension i found out that the headlight levelling system also plays a part so another path to explore if fitted (they tend to get moisture in which corrodes the board) and as you are in the US it is behind the panel by your left leg down by the carpet its the grey box)
Hope this is of some help
Post #696316 16th Jul 2024 4:56pm
CS
Could be a failed ABS sensor. My 2004 4.4 had that, with that warning. If it is that, check whether the cause is a driveshaft swollen by corrosion fouling the sensor, if so that needs sorted too. Only Range Rovers since 1988
Post #696317 16th Jul 2024 5:34pm
invisible999
How did you fix it? What was the replacement part number in your case?
Post #696334 16th Jul 2024 8:58pm
invisible999
I live in a desert - last snow was in April and next one will be in October. If we exclude moisuture induced corrosion, what else?
Post #696335 16th Jul 2024 9:00pm
CS
Sorry I can't help with a part number as I got the dealer to do it, and I no longer have the receipts for that car. It's probably best to get a diagnostic check done first. I take your point about corrosion being less likely where you live. Only Range Rovers since 1988
Post #696337 16th Jul 2024 9:09pm
roadster88
United States 2006 Range Rover Supercharged 4.2 SC V8 Chawton White
I had the same thing but eventually went away when I started driving the car more. I had let the battery voltage get real low while I was doing a bunch of work on the car. I charged it back up on a slow charger to where it would start again but it still wasn't 100% charged.
Now after driving it regularly the battery is back to full voltage and the suspension and HDC failed went away.
Post #696348 17th Jul 2024 2:34am
invisible999
Are we talking about this?
I unscrewed it and looked at the part number
They are running about $150-$300 on eBay but there is disclaimer that you need to recoding. Do in addition to $150-$300 do I need to buy a separate tool for >$400 just for recoding?
Post #696458 18th Jul 2024 7:46pm
dingg1
No, abs wheel speed sensor in each hub.
Your picture is your abs unit, if you need to get another there's a module number stamped in the steel part, get one with the same numbers and it doesn't need coding...
Post #696461 18th Jul 2024 8:09pm
invisible999
Kinda lost here - where in steel part?
Post #696465 18th Jul 2024 10:45pm
dingg1
You see that big plastic thing, look behind it, the lump of steel with the brake pipes in it, that will have a set of numbers stamped/etched into it, match them up no need to be coded
Hth
Post #696466 18th Jul 2024 10:49pm
Dolphinboy
Are we talking about this? - YES
If you unplug the bottom head nearest the front (pull upwards) there are a lot of pins which make up the plug in part. On mine there was green corrosion on several pins leading to HDC, ABS, suspension lights appearing on dash. A quick clean up with a toothbrush and spray with contact spray cured mine (the Stealer wanted me to pay £1000 for a new ABS unit Shocked )
worth a look. Thumbs Up
Post #696469 19th Jul 2024 12:59am
invisible999
Hth
So do I need to remove the ABS unit first like I did to read the part number?
Post #696471 19th Jul 2024 5:31am
invisible999
So you did not even replace the ABS control unit, just cleaned it?
I tried to unplug the cable, it did not work - are there any clips from either side that need to be taken care of to be able to unplug the cable?
Also, did you just unplug the cable or remove the ABS unit first and then uplug the cable?
Post #696472 19th Jul 2024 5:33am
invisible999
One more thing and to recap...
When I first time got this problem and turn on/off ignition and checking fuse 56 did not help, I used All Comms II reader. It got me following
MKIII Communications Performed by RSWsolutions - All Comms Software.
L322 Anti-Lock Brake Module Query Results: Performed on 7/11/2024 5:02:37 PM
0x58   0x0058   Precharge pump.
0x5A   0x005A   Temporary system deactivation.
0xE   0x000E   ABS valve relay.
L322 Air Suspension Module Query Results: Performed on 7/11/2024 5:04:09 PM
Air Suspension System Fault Reading Complete...
0x1E   0x001E   Front Left Height Sensor Fault.
0x32   0x0032   CAN bus Fault.
Once I cleared both, the ABS valve relay and Front Left Height Sensor Fault did not come back, but Precharge pump and CAN bus Fault remain.
What I am getting here and from other places as well is that these messages are actually cascading down from another issue, most likely ABS and that issue needs to be addressed first. And thanks to everyone who provided useful information.
So this week I ordered this thing hoping that I could get a better insights.
https://www.amazon.com/dp/B0B4MJ5NK6?psc=1...ct_details
Well, it is going back because... it is made in China, from Chinese company, with Chinese support only at whatsupp. And 'diagnostic report' is uploaded to Chinese cloud and only is this
I tried to contact via whatsupp - no dice...
Post #696473 19th Jul 2024 5:45am
