![]() | Home > In Car Electronics (L322) > CarPlay for under £100 |
| Driyage Member Since: 30 Apr 2024 Location: Essex Posts: 55
Hi,
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
You might want to search out a post detailing a very neat modification to the rear aux which allows a lead to be plugged in permanently and the lid to still close.
| madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 116
Not much trim needs to be removed. You can feed the power cable ( and the aux) under the dashboard and pick it up in the front corner.
I’ll keep searching, but basically you just need a 3.5mm aux extension lead with a 90’ plug on the end that plugs into the socket., meaning no modification to the existing car wiring.
| RINOR Member Since: 10 Oct 2021 Location: VIKEN Posts: 7
Could you please post a new link to this unit? Tried it, but comes up with “unavailable”. Thanks😊 |
The exact one that I got is not around now.
Thanks Baltic Blue. I actually already do this. I was thinking of a wiring mod to completely hide the aux cable in the armrest somewhere. Yes, I know I’m ocd…………….. |
Ok took the plunge today and removed the centre vent, and ran the wires down to the fuse box.
Ok I think I found Aux input mod:
I know that I have read a post detailing a very simple mod to the rear aux socket, but have not managed to find it using search.
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758
With regard to modifying the rear auxiliary socket (2006-2012 L322s) what I've done in all of mine is remove the plastic cover below the flap which conceals the auxiliary port and power point.
So with thanks to madnessgonemad I’ve finally done mine:
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871
theres a much easier mounting solution discussed in this thread,
That’s a neat solution, thanks! I’ll look through the thread to figure out the wiring for that |
