Home > Technical (L405) > The engine has died
Smp68
United Kingdom 2015 Range Rover Vogue SE TDV6 Santorini Black
The engine has died
On my 3.0 TD6 (with 190k miles 15 plate). As I was driving the engine cut out and the red light came on. When I put the code reader on it came up with
P0340 camshaft position sensor A bank 1 malfunction
P0087 fuel pressure low
U2e10(DF) engine control unit.
Have got it to a garage and they said the crankshaft is turning but not the camshafts.
They say the engine needs a rebuild and have recommended QP Online Ltd in Maidstone. They have quoted £10000ish just in rebuild and can't do anything until November. We are based in Verwood Dorset.
Does anyone have any suggestions. We would also need a spare runner for this time. Sad
Post #696318 16th Jul 2024 5:40pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
Sounds like the crankshaft has broken, which will cost much more than £1000 to put right!
Best advice is to start saving.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #696323 16th Jul 2024 6:16pm
Smp68
Sorry I meant £10000. Fat finger typing and stressed partner.
Post #696326 16th Jul 2024 6:32pm
Scouse Exile
Would you not be able to engine swap it for a 2nd hand unit for less?
Jon
Post #696346 16th Jul 2024 11:18pm
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Autotrader?
Post #696352 17th Jul 2024 6:55am
