![]() | Home > In Car Electronics (L405) > Next noddy question |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
Probably turned off by the previous owner. This is how to do it on my MY17, which may be the same on your MY.
M3bobby Member Since: 28 May 2019 Location: Lincolnshire Posts: 17 ![]() ![]() ![]() |
Perfect, that worked straight away. Thanks! |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1832 ![]() ![]() ![]() |
Not advisable to do that:
I would hope that with the recent security update, the keys living in a faraday bag, separate immobiliser, telemetrics tracker and best of all, armed guards, I should be good. I had my last one for 6 years without issue…until a campervan decided to hit me head on. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
If you turn off keyless entry, it almost eliminates possibility of relay theft. 2015 Range Rover Autobiography 4.4 SDV8 |
Was that a question or statement Gary? |
A statement, however I chose my words carefully. There are some circumstances under which theft of the vehicle can occur with keyless turned off. 2015 Range Rover Autobiography 4.4 SDV8 |
It comes to a point that too much security just gets in the way of using the vehicle. My last Range Rover was fine for 6 years, no car has been stolen from where I live, my keys live in faraday pouches a good 20 meters from the car, it lives behind gates at the back of the house, it’s got a separate immobiliser, a tracker with a card to activate before you drive etc. etc. At work it literally has armed guards so there’s little chance of it being stolen. And the best thing is, I can turn it off and on in about 3 seconds now I know the trick. If I lived in a city I’d probably have it turned off at all times, but living in the arse end of the U.K. does have its benefits. |
TomekW Member Since: 01 Jun 2023 Location: Warsaw Posts: 10 ![]() ![]() ![]() |
thanks for sharing
