![]() | Home > Technical (L322) > P023D-22 (2C) Manifold absolute pressure |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1357 ![]() ![]() ![]() |
Hi Matt, I put a K&N filter in a Ford Explorer and the oil mist off the filter kept clogging the MAF sensor. Put a genuine filter in If I was you.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1017 ![]() ![]() ![]() |
Clean the MAP sensor with carb cleaner - don't be tempted to prod and poke into the 4 holes
EvolutionUK Member Since: 03 Jun 2024 Location: Hampshire Posts: 14 ![]() ![]() |
Thanks chaps. Great point regarding the oil mist Kevin. I hadn’t thought about it! I’m going to take a look at cleaning all the sensors. It has only happened a few times cruising with slight load. Codes can be cleared. Turning off the engine and re starting also fixes it, so I’m hoping it’s just grime build up as it was evident it had been a bit neglected. It’s the 3.6 08. I brought it to see what all the hype was 🥴 |
