Home > Technical (L322) > 2006 L322 TDV8 battery drain - blower motor running
DaveKnell
Cyprus 2006 Range Rover Vogue SE TDV8 Stornoway Grey
I've a 2006 TDV8 with what seems to be a common issue - the blower motor runs continuously when the ignition's off, eventually draining the battery.
I've pulled all of the fuses that looked like they could have something to do with this - F12, 34, 52, 61, 64 and the damn thing keeps on running. I've had a good search but can't seem to find a next step.. anyone help?!
Thanks in advance --
Dave
Post #697226 1st Aug 2024 12:26pm
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
Sounds typical of FSR (final stage resistor) failure. There is a good write up re it’s replacement in the Wiki on this forum.
Post #697230 1st Aug 2024 12:47pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Yes the FSR has failed only solution is to disconnect the battery to stop the fan then replace the unit. It’s a fiddle but can be fine at home. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #697235 1st Aug 2024 3:58pm
