![]() | Home > Technical (L322) > 5.0 Supercharged Hesitation |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2280 ![]() ![]() ![]() |
David I had something similar on my 4.2 and it turned out to be a pressure sensor that had an intermittent fault we found it by chance |
Floopy Member Since: 28 Jan 2023 Location: Devon Posts: 84 ![]() ![]() |
I recently had this on my 4.2 stuttering under high load conditions such as climbing a hill with a heavy load or full throttle in a high gear, even stuttered enough to go into limp mode but with no fault codes showing on the IID. Fine in all other conditions though, even hard acceleration if the load was not too high.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3255 ![]() ![]() ![]() |
I’ve not driven the L322 for about a fortnight now so I took it for a run tonight. It was meant to be booked into the local specialist for a high pressure smoke test today but due to a tech having a family emergency they had to cancel and rebook.
After a bit more reading this morning, I’m convinced it’s the MAF sensors. I could be wrong, but there’s my logic…
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 92 ![]() ![]() ![]() |
Does the fuel pressure rise when you switch the engine off?
Thanks for the suggestion.
My oil level did increase but it took its time to show on the digital gauge, it was most notable when doing the actual oil change.
I’ve done 100 miles in the car today and can report the following:
I’m wondering if I’ve been going about this the wrong way…
Ok, it looks like it’s not something that’s gearbox related. You can see on the attached video that whilst the engine revs are fluctuating the gearbox input speeds are rock solid.
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 760 ![]() ![]() ![]() |
Needle in a haystack springs to mind!
Awall13 Member Since: 08 Aug 2024 Location: TN Posts: 1 ![]() ![]() ![]() |
Did you happen to find a resolution to this? Old thread but mine just started doing this on the way to work, odd hesitation at low rpm under load. Doesn’t really feel quite like a coil to me but that was my first thought. |
I did indeed.
