Home > Maintenance & Mods (L322) > Solid brake pedal after a week of not being used.
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
I thought I'd read somewhere here on the forum about this issue in the past, but despite searching today I've not found the thread. Censored
2012 TDV8 Westminster - Car is fine, brakes are fine, starting isn't an issue.
But.... If she has not been used for a week, I can find a fairly solid brake pedal before starting the car for the first time. This simply means that it needs a fairly firm press on the pedal with minimal travel to initiate the cold starting sequence. Doesn't happen throughout the rest of a day, just the cold morning start.
Something tells me there's some kind of a vacuum leak that's only going to get worse over time. But where? Confused The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #697892 12th Aug 2024 1:54pm
JayGee
Mine's the same but happens overnight. Changing the servo one way valve but didn't resolve it. Reckon the servo itself is leaking so I just live with it. 2012 TDV8 Vogue (L322)
Post #697920 12th Aug 2024 6:59pm
supershuttle
Although this is an L322 thread, it might be worth noting that mine also does it - L405. I also "just live with it" Geoff
Post #697923 12th Aug 2024 7:33pm
I'm with Geoff, my 405 does it overnight, as soon as it starts the pedal drops so I'm happy to let it be, done it everyday of my ownership, nearly two years and not changed or got worse... Thumbs Up Pete
-Click here for Thread-
Post #697941 12th Aug 2024 11:38pm
Fox889
2012 L322 Westminster……exactly the same if left for a week or more.😁 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #697951 13th Aug 2024 8:36am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Can confirm, my old 5.0 L322 used to do this, always meant to do more investigation, but it never gave me cause to, so I lived with it. as soon as the engine started it went back to nice and progressive.
On spectrum of L322 foibles, this was one of the pleasant ones Laughing Formerly happymadison1978
Post #697998 13th Aug 2024 4:19pm
JayGee
Glad I'm not alone. Time to remove this from my to-do list...... 2012 TDV8 Vogue (L322)
Post #698026 13th Aug 2024 9:43pm
