![]() | Home > Maintenance & Mods (L405) > Oil Service cost |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
Does it state what work was actually done ?
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
My car didn't need a service as such, I just wanted an interim oil change and requested as such. It's not due for its next service until early next year, based on LR's own maintenance schedules.
In that case, completely OTT.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1855 ![]() ![]() ![]() |
@Buz1500, as Alistair has said, it’s super simple to DIY, and only about £30-£40 per change once you have the gear, which you will easily get the money back for the first time you do it. There’s loads of info on here to show you what you need o get the oil sucked out & change the filter, plus the WM up above to help you. LR MD’s are a total rip-off, it’s only 1/2hr job, and most of that is standing around waiting for the pump to do its thing. :thumbsup: |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1482 ![]() ![]() |
Just did my first oil change with a suction pump. Super simple and, even including buying the pump and 36mm socket, was less than £100. Next time it will only be around £60.
Thanks for the replies, certainly food for thought. 2019 L405 SDV8 Autobiography
Cheapest way I could get C1 5W30 LR oil was Smith & Allen £63.88 for 20L, about £70 delivered. That does 3 fills for my TDV6, plus 2L left over for top-ups (which it never needs). So £40 a time including filter. You will only get 2 fills, but still around £45 a go DIY ( once you have the pump etc).
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
I don't use the Smith & Allan oil becuase it doesn't have the JLR approval (doesn't mean it's by any way inferior however; just my personal preference).
@GaryRR:
Meets, yes. Approval, no.
I guess that’s possibly only really important if folks have a JLR Warranty, rather than 3rd Party.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3382 ![]() ![]() ![]() |
I used Petronas last service. The viscosity and ash content are the only important factors with this oil and I don’t need JLR ‘approval’ to assure me that S&A’s C1 has this. Any details of what JLR’s actual testing involves in order to get approval? 2012 TDV8 Vogue (L322) |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1412 ![]() ![]() |
Jlr won't do any testing on their approved oils.
Assumed it was so…. 2012 TDV8 Vogue (L322) |
