![]() | Home > Technical (L322) > Battery Drain, Fuse 12 and Aircon Control Panel |
Paddy X350 Member Since: 15 Nov 2023 Location: Wexford Posts: 63 ![]() ![]() ![]() |
So I have continued to investigate this and it seems Fuse 12, which feeds the aircon control panel is definitely in the frame for a large portion of the battery drain.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1017 ![]() ![]() ![]() |
When I press MAX on my 2004 car, with ignition off, it does not do anything Chris |
That's great, thanks for doing that.
So I received my NOS aircon control unit from Ebay today, fitted it and monitored the battery drain.
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 190 ![]() ![]() ![]() |
Hi, I’m sure on my 2010 L322 you can press the max ac button when you park up and it will blow warm air into the car when you get out, it keep the cabin warm when you leave the car for a short while. |
