Home > Maintenance & Mods (L322) > Stiff gear lever movement
ken0204
2005 Range Rover Vogue 4.4 V8 Stornoway Grey
Hello All,
The lever became stiff to move through the gate after a week long layup in the airport carpark.
All moves and engages and goes ok but a good push is needed to move the lever.
I looked underneath to see if any linkage could be oiled but only saw the kick down cable.
The beastie is a 2005 V8 with the gearbox oil and filter changed every 40k
Where is the linkage and how do you get to it -from the bottom or top?
Home job or garage?
All knowledge gratefully received! Confused
Post #69731 23rd Jun 2011 11:14am
I recently posted on this. You need to get under the car and spray loads of WD40 on the gear linkage on the side of the gearbox and easily visable on drivers side I think. Drain/Level plug is on the other side. THe Linkage is VERY prone to corrosion especially when a car is left unmoved for a period. Thumbs Up
see: http://www.fullfatrr.com/forum/topic6333.html
Post #69733 23rd Jun 2011 11:28am
Corrosion after a week is a bit poor!
I'd guess your corrosion has been building up for a while.
Good catch by Gaz though. let us know if this works. Discovery 4 HSE
1993 90 Tdi
Post #69749 23rd Jun 2011 1:22pm
It builds up and is a common problem normally highlighted after the car is left standing for a while...
Gary
Post #69757 23rd Jun 2011 2:16pm
ken0204
Thanks Gaz
A big can of WD40 it is then! Thumbs Up
Post #69784 23rd Jun 2011 8:14pm
Let me know how you get on but it worked for me Thumbs Up
Post #69801 24th Jun 2011 12:19am
i shall have to remember this for when mine gets stiff... Thumbs Up
Post #69809 24th Jun 2011 8:30am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Having suffered from WD40 use in the past - it's technically a water dispersant not a lubricant - so some marine/ agricultural waterproof grease or ptfe spray might be better http://www.screwfix.com/p/no-nonsense-ptfe...id=1999825 ...
Post #69846 24th Jun 2011 2:53pm
WD40 does work but I agree there are better lubricants.
Post #69847 24th Jun 2011 3:44pm
He hey! This seems to have fixed my gear lever problem too, Thanks Gazellio:
http://www.fullfatrr.com/forum/topic4657.html?
[EDIT] spoke too soon, still not "PARKING" properly .
Post #69915 25th Jun 2011 12:14pm
