Home > Technical (L322) > 4.4 TDV8 Restricted Performance
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
Hi All,
My car is intermittently going into restricted performance mode.
My MAP sensor is clean and I clean at least monthly using MAF cleaner.
There is no sign of a leak via the 4 doughnuts albeit I have only had a quick visual look.
NS Turbo Actuator was replaced a few 000 miles ago with a new one.
It doesn’t go into restricted performance mode when you rev to 3000 which I do regularly to keep the second turbo in regular use.
It only seems to happen when I rev beyond 3500 to 4000 revs and even then it’s not always.
Can anyone point me in the right direction and advise if it’s a DIY or specialist job.
Many Thanks
Brian 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #698425 19th Aug 2024 11:00pm
rjff
Hi Brian
Do you have access to a GAP or diagnostics kit?
If not may be able to assist. Cheers
Richard
Gap IIDBT
Post #698429 20th Aug 2024 7:41am
Fox889
My first question would be…..why on earth are you revving the poor girl between 3500-4000rpm? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #698431 20th Aug 2024 8:31am
JayGee
Pull some codes or log some data - anything without this is speculation. 2012 TDV8 Vogue (L322)
Post #698432 20th Aug 2024 8:44am
Dolphinboy
Inlet manifold? do a HIGH pressure smoke test.
Later models had an uprated manifold as the previous one couldn't take the boost of 2 turbos apparently.
Post #698434 20th Aug 2024 9:32am
Eastsoutheast
It’s a 2012 if that helps re the comment about later models having an updated inlet manifold.
I do have a Gap tool which I purchased on here 3/4 months ago, haven’t got around to buying the license and using yet!!
I will buy the license and report back here for a steer on what to look for.
Thanks 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #698500 21st Aug 2024 4:34am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Max power is at 4000 rpm
Max torque 3000 rpm
Between 3-4000 rpm, the engine is incredible
You can use this car without exceeding 2000 rpm, as there is so much torque available from 1500rpm
But such a waste IMO
Each to their own
Post #698502 21st Aug 2024 7:07am
JayGee
Thanks
You don’t need a license to read fault codes. 2012 TDV8 Vogue (L322)
Post #698505 21st Aug 2024 9:08am
Eastsoutheast
I rarely take it beyond 3000 RPM, maybe once or twice per month. I think it’s important to give the car a chance to stretch its legs once fully warmed up. Being an old girl I am very smooth with all inputs so the run to 3500/4000 RPM is done progressively so as not to put unnecessary strain on her. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #698507 21st Aug 2024 9:12am
GraemeS
Australia
Mine gets up there occasionally when I'm wanting maximum acceleration overtaking in a short distance. Unfortunately speed limits mean that the run is very short-lived.
Post #698512 21st Aug 2024 10:18am
Eastsoutheast
The last few times it’s happened it cleared itself following pulling over and turning off the ignition. I do have a OBD reader that communicates with Torque and this shows no stored fault codes. The same reader correctly diagnosed a faulty turbo actuator a year ago. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #698514 21st Aug 2024 11:02am
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
I agree but the issue is where the hell can you use that oomph without hitting the legal speed limit 3 seconds after stamping on the fun pedal !. Just overtaking an artic on an A road means you nearly hit 100 by the time you get past , you have to be really careful overtaking 3 with a caravan on the back !!!
Max torque 3000 rpm
Each to their own
Post #699344 2nd Sep 2024 8:50pm
Rambles
For folks that think their cars are overpowered, and should all be artificially limited to national speed limits with no over-ride, the EU is coming to your rescue.
Post #699398 3rd Sep 2024 7:07pm
