![]() | Home > Technical (L322) > A few battery drain questions… |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 467 ![]() ![]() ![]() |
I recently had a no start followed by an ignition lock.
Yes, I am looking at getting a charger that tests battery health (Ctek Msx 5.0) as I need to upgrade my simple battery charger anyway.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1017 ![]() ![]() ![]() |
MY04 Range is always connected to a CTEK MXS 5 when I'm not driving it, there are any number of battery drains on these earlier cars, good luck finding the culprit ! |
Paddy X350 Member Since: 15 Nov 2023 Location: Wexford Posts: 63 ![]() ![]() ![]() |
I have a battery drain, there are a few good strings here on how to track down the culprit if you do a search. You need a clamp meter on the battery negative, put the car to sleep and start pulling fuses.
Thanks.
I am still waiting for my Ctek charger to arrive to health check my battery, but noticed it’s an AGM spec version (see below), obviously I don’t have stop-start! Guess this is not a problem, I certainly have had no issues over the past 2 years with it.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
AGM trumps all other types. Keep it |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3381 ![]() ![]() ![]() |
Don’t install an AGM battery unless the car has an AGM compatible charging system. 2012 TDV8 Vogue (L322) |
I guess the question is does a pre-facelift 2009 model have an AGM charging system?!
If it was dealer fitted it's certainly the right one but 10yrs old likley past it's best. I'd replace and then see how it goes with regards to voltage loss over time. 2012 TDV8 Vogue (L322) |
Interestingly this place sells the oem AGM replacement battery (at a hefty price) and quotes that it fits L322’s from vin 7A…
Another thing that may explain my issues is that having only recently found out I had an AGM battery I may have somewhat ruined it by charging it up with a standard Halfords charger - which I read is not suitable voltage wise.
Get an AGM one from Tayna and do the battey update procedure in the GAP IID tool so it can do the cycle charging properly. 2012 TDV8 Vogue (L322) |
I don’t own a Gap IID tool, what is the best value one to buy that will do most of what I need it to do?
