![]() | Home > Maintenance & Mods (L322) > l322 4.4 tdv8 - mechanics can't solve the puzzle - egr dpf |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364 ![]() ![]() ![]() |
I say this quite often but it's worth checking the drain back valve directly under the oil filter itself is on it's locating post.
Georgi Member Since: 05 May 2024 Location: Sofia Posts: 23 ![]() ![]() ![]() |
Hi kevinp,
Just unscrew the filter mate. The filter itself presses down on it. Dead easy just to rule it out.
aaah, got it, I read about it, sometimes they put a non-conforme filter and it presses the thing with the spring all the time down - if that is, I will check it, thanks! l322 2011 4.4 TDV8 Autobiography Black
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342 ![]() ![]() |
If you are not getting the problem now - it would be a good idea to get an IIDTool and to monitor the sooting in the DPF while driving.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3396 ![]() ![]() ![]() |
I have to say that 30mins daily runs are not ideal for DPF equipped cars. 2012 TDV8 Vogue (L322) |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 112 ![]() ![]() ![]() |
Abbreviated long story as i know the reason for the original cause over a year ago (lowish fuel and nightmare journey), but having had mine go into limp mode numerous times and then being force regened for it all to happen again a month later i finally bit the bullet and took the dpf off (only 2 cuts on tailpipe as my local place has a machine big enough to put the whole front section in after unbolting from cat/turbo), not had and issue since (that was March) , check it's all working now and again with gap tool and all tickety boo, be very careful with forced regens and resets of system as they often don't work properly and can cause other parts of the system to overheat (I cooked RH O2 sensor on my last and far too long attempt at a forced regen), tkae it off , have it properly cleaned and do longer journeys , as anothe rposter said 30 mins a day is not enough , take it out once every couple of weeks for a 30/60 min run above 50 . |
Update - I did a smoke test and the mechanics said no issues. So the troubleshooting continues.
For a daily 30min city driver the 5.0SC is a much better choice. 2012 TDV8 Vogue (L322) |
Hi Georgi, your problems are definitely not helped by living in the city, and possibly that is the cause if you are just doing short drives in traffic. Forced regens are designed to be used as an emergency measure. For this reason it took years until we were able to get the the functionality added to the IIDTool. Performing forced regens as a regular measure is not a good idea - it has been suggested this will create other problems, like damage to the DPF ceramic matrix. I strongly recommend you do not Force Regen regularly. Baltic Blue has some experience of this I think?! Good luck, Matt 2012 L322 4.4 TDV8 AB low mileage - a peach 1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) Last edited by Range Rover L322 on 6th Sep 2024 7:37pm. Edited 1 time in total |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352 ![]() ![]() ![]() |
In all honesty, as per above, you bought the wrong car for you circumstances |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1026 ![]() ![]() ![]() |
[quote="Georgi" some guys delete EGR Thanks |
Hi guys, update - I just touched the engine bay for the first time ever |
another update
