Home > Maintenance & Mods (L405) > Fuel filter prime
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Fuel filter prime
Planning on doing all the filters on the TTV6 in the next couple of weeks and I am wondering if there are any tricks to bleeding/priming the fuel filter?
Thanks
Pete
Post #698867 26th Aug 2024 7:08pm
garyRR
No issues as such priming it, but you may get a water in fuel sensor issue.
Fill the filter with diesel first and then attach the water in fuel sensor. Then flip it over, fit it to the housing and remove the rubber caps from the hose ports and attach all hoses.
Cycle the ignition 5-10 times for 10 seconds.
Then start the engine. 2015 Range Rover Autobiography 4.4 SDV8
Post #698871 26th Aug 2024 9:28pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
As Gary said - the filter will self-prime with the ignition on. I don’t pre-fill the filter and it still primes without any issue at all.
Post #698873 26th Aug 2024 9:59pm
Spridget
Thanks lads. It's my first DIY big service with this car so just psyching up for it.
Post #698984 28th Aug 2024 8:39am
