![]() | Home > Maintenance & Mods (L322) > Help needed - changing rear bushes |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
I'm just going to knock up a tool myself at home but if I can't get hold of the right sizes of tubing I'll order the same one as you. I presume you've got it now and verified it fits? I bought the bushes last night so will sort it on Sunday if the weather stays fine. I checked the price of the LR tools the other day - very expensive! |
If this is a quickish one off job I am sure it would be cheaper paying an expert indy £60 for an hour rather than buying tools to be used just the once etc.. |
It'll be more than an hour to do both sides. Probably 3 all in I would guess. For me it's a convenience thing as well. The more I can do myself the less times I have to take a day off work just to give a car to someone else while I sit around waiting for them to finish. |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
rory_mcw Member Since: 08 Apr 2009 Location: Angus - Scotland Posts: 113 ![]() |
i got a friend to do them on my last car, he said it was a nightmare, im mechanically minded but its not worth the hassle, mine were badly seized.
Mine are all done, by Keith at Caldwell and Dempster in Banchory, Keith knows all Land Rover inside out!!!.
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Top bush changed - an absolute doddle with the Vectra tool |
Any update on the bottom bushes? |
Not as yet - I've a socket large enough to fit the bearing to push it out but nothing as yet big enough to fit around the bearing to allow it clout of the arm |
Looking at your pictures you have shown more than top and bottom rear rose bushes, are the wishbone bushes needing renewed? Also I see front castor arm bushes and ARB in the pictures have you done them yet?
I had at 73,000 miles play in the inner swinging arm bushes both top and bottom, outer knuckles were shot, toe arm was replaced as this far in, only bushes not touched were the chassis under frame 4 carriers , but they are on the to do list!! at some point, these can be a right b...er appartently.
