![]() | Home > Technical (L322) > Weird electrical gremlins |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1778 ![]() ![]() ![]() |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 785 ![]() ![]() ![]() |
Not actually thought of that gremlin, I did go through some river crossings in the Highlands the other week and on way back it was absolutely lashing it down most of the way. Are they easy to get to so I could do them myself? I have read they corrode on the L322 as well. We'll see how I get on tomorrow with new AGM battery. |
Check the WM on the L322 up above^^^
Thanks gremlin. Can't do any harm taking them off and giving them a good clean and brush up. |
So this evening I fitted the new AGM battery, fired up like never before, coded it to the car and cleared all faults. Took it for a test drive and what a difference it's made. The suspension is loads better, a much comfier ride like it should be and actually I do believe it drives much better. Another thing that I noticed, I used to have what sounded like a very faint squak when I used to ease off the throttle and a very faint rattle, both have now disappeared. The side steps go in and out much quicker than they did before. Who knew a failing battery would cause all sorts of gremlins in these beasts. Something to remember in a few years time when it starts failing again. |
So today before leaving work, I thought I would check the voltage through the gap tool and it shows 12.3v at tickover rising to 13.2 when revved. I had an hospital appointment so thought I would I check the voltage again while driving which is a 45 minute drive. The battery state of charge was fluctuating between 79% to 81% and voltage was showing anything 12.1v to 13.7 while driving along. Pouring with rain, headlights, wipers and heater on low battery charging status didn't drop below 79% although the voltage fluctuated getting higher to around 13.6v when accelerating and also on deceleration. Not once did it go over 14v.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1324 ![]() ![]() ![]() |
I'm sure I've read that the system is only designed to charge the battery to 80% but I don't know why. |
I read somewhere on here Kevin that's what it goes upto on the 2011 4.4 with the intelligent charger. That seems all ok according to the gap, it's just the voltage that's concerning me. Or am I worrying over nothing? But reading up on here on various posts the battery voltage should be over 14v. |
@BarmyBrummie:
Thanks gremlin. I must be worrying too much after reading various posts on here about voltage and alternator problems. Sometimes a good read of technical issues can get the better of me lol. Much appreciated. |
