![]() | Home > Maintenance & Mods (L405) > Tailgate thinks its open |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8022 ![]() ![]() ![]() |
How recently is 'just bought' ? and was it from a dealer ? Any warranty ?
chicb Member Since: 28 Nov 2019 Location: Dundee Posts: 114 ![]() ![]() ![]() |
Just bought as in 2 days ago. Dealer 300miles away & has a warranty but not got docs yet.
Was it a main dealer ?
Not main dealer |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1721 ![]() ![]() ![]() |
Can you hear the “brrrrrrrrr” of the tailgate motor (latching) for a few seconds after the upper tailgate first closes?
As its a plug in hybrid P400E, does it have a normal battery as well as the battery for the electric motor or does the battery bank take care of everything. I charged up the hybrid last night, so its at 100% & as the car was collected from 350miles away any other battery would be well charged
Yes it also has a 12V battery as well as the HV hybrid system. If the 12V battery is depleted it may charge to only a fraction of its original capacity, so it can easily become discharged again, especially if stop/start happens a lot. It may be a red herring, but it’s quick & cheap to check. Sluggish tailgate opening and/or sluggish deployable steps are common indicators of a weak (12V) battery, (although steps can be slow due to mechanical reasons.)
Thanks for that. |
The iiD tool is about £500, but just has so much more functionality than others, and will pay for itself many times over. I bought the iCarSoft LRV3 myself, (£175) which is a good compromise, although having only 1 guy on tech support can be a bit slow sometimes.
I do use Mikey for my Sport. I phoned him about this but he is over the top just now & could not give me a date to see the car. Went to see a friend of mine who owns a garage. He cleaned up the docking points, initially it worked then failed. After a lot of trying he gave it a hard manual closure which enabled the car to be locked & useable as long as I don't use the boot it will be fine until it goes to the main dealers on Tuesday. Thanks everyone, will let you know the outcome. |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 841 ![]() ![]() ![]() |
Don't forget the secondary 12V battery from the right side of the boot, it's responsible for a lot of concerning stuff as power braking, ABS, etc... |
Car been to Main Dealers, apparently the strikers were out of position, re-adjusted, now working fine. Charged for 30mins labour, which I thought was fine.
