![]() | Home > Wheels & Tyres > Tyre sizes on different axles |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 799 ![]() ![]() ![]() |
A totally unacceptable idea for any permanent four wheel drive car from a safety perspective, whether it has locked diffs or not. There is nearly ten percent of a difference in the sidewalls of these two tyre sizes. Your front and rear tyres would be turning at different speeds in a straight line. Driving round a corner, all four wheels would be turning at different speeds. This crazy idea will kill your transmission in a relatively short space of time as the centre diff will be constantly wound up with every mile. Beyond this, when it all lets go and you have an accident, the insurance company will simply walk away. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3334 ![]() ![]() ![]() |
With a properly calibrated and functioning suspension system the front tyres should be nowhere near the wheel arch liners. Many people run the larger 255/55 R20 without any problems and the only time you might get some rubbing is if the suspension completley deflates and you attemt to drive it. Suggest you look into the height control on the air suspension first. As JMC says it's not an option to run different rolling radius tyres on a 4x4 so forget that as a solution. 2012 TDV8 Vogue (L322) |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 300 ![]() ![]() ![]() |
I am running 255/55 R20 on my Vogue SE and there is no scuffing at all. Maybe someone had larger tyres fitted in the past and that caused the scuffing.
Notyalc Member Since: 23 Dec 2022 Location: Northumberland Posts: 7 ![]() |
Have you got standard rims? Have you got spacers? Height been altered? All of these things can have an effect… |
Billy'sLad Member Since: 02 Jul 2021 Location: Southport Posts: 8 ![]() ![]() ![]() |
Thank you all for your replies.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
255/55 were never fitted to the RR as standard or an option, that’s why it’s not in the handbook. 255/50/20 is the largest tyre fitted by Land Rover, but quite a few folk have fitted the 55 profile without issue. I think there is a better choice of off road tyre there.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8110 ![]() ![]() ![]() |
On the handbook question - 255/50/20 is the original size.
I did the same on mine with 255/55 R20 when a height sensor failed and noticed the slight scuffing hence why I'd not recommend larger tyres than these as it could render the car unmovable in such a circumstance. Also be aware that with the 55 the speedo reads dead on or even slightly under the actual roadspeed so easy to get into trouble with speed cameras. 2012 TDV8 Vogue (L322) |
