Home > Technical (L322) > I killed my L322 (edit: fixed / dead battery)
tspd
Hi all,
Was fiddling about with changing the rear indicator bulbs to LEDs. Inserted the indicator bulb, seemed to be working OK with just hazards on. Didn’t start ignition.
Moved on to brake and fog - installed these. Started ignition / engine - multiple faults about rear lamps, then immediately parking brake failure, TPMS failure. All warning lights flashed up then disappeared.
Now when attempting to start, the parking light warning light flashes, the rev and Speedo needle “vibrates”, the wipers activate veeery slowly. Obviously no engine start.
Maybe my meddling has fried something. Can’t access fuse box as glove box won’t open…!
Maybe dead battery?
Edit: noticed the interior lights are very dim, and when putting hazards on (refitted the original bulbs) they dim when the lights flash. Perhaps I killed the battery? L322 2007 S/C 4.2L (first full fat)
135k miles and counting
Buckingham Blue
Post #699766 8th Sep 2024 12:36pm
mjdronfield
On my 2003 td6, different electronics I know, I never got LED indicators to work. They were ok on hazards as that’s a decent load on the LCM but on left and right turn they flashed far too fast. Prob needed resistors etc.
Your brake lights will be LED already. Just side and fog at the rear.
I’d charge the battery fully then disconnect it for 10 or so mins to see if the car resets.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #699769 8th Sep 2024 1:01pm
tspd
Thanks. I'll try get it jump started.
It seems all like low voltage symptoms - just tried again and error of transmission fault detected came up. Tried to start and a click noise from engine appeared which seemed like starter motor trying to get going.
Unclear how the LED bulbs could have caused the battery to discharge so quickly - short circuit perhaps? L322 2007 S/C 4.2L (first full fat)
Buckingham Blue
Post #699783 8th Sep 2024 4:58pm
mjdronfield
I’m no electric expert so don’t know how anything could have happened, though I know it doesn’t take long for my car to throw Low Battery Start Car on the dash if I have the doors open and interior lights on for any length of time. Gone are the days of having the car radio on whilst you wash it 🤣. Maybe just that did it, but imagine you’ve done loads of stuff with doors open etc and engine not running.
They don’t like low voltage, throw all sorts of errors. Maybe the LED bulbs didn’t cause the low battery, so up to you if you try them again with a fully charged battery.
All I know about LED is some you have to turn the other way round if they don’t work and they use less power, so can throw a bulb failure message if not Canbus friendly etc.
I know there are loads of threads on the forum about them. Should be doable. I added LED side indicators to my 2011 car to match the others.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #699788 8th Sep 2024 6:00pm
tspd
Thanks for help everyone.
It was a dead battery - jump started and driving.
I suspect the cause was leaving the doors open when swapping all the bulbs round.
However I now have a check rear light, side light and flashing yellow adaptive headlight warning. Prior to jump start I removed all LEDs and back to stock. They’re all working fine so not sure why it’s complaining.
I’ll try reset and disconnect the battery to see if that helps (unless anyone has any other ideas). L322 2007 S/C 4.2L (first full fat)
Buckingham Blue
Post #699800 8th Sep 2024 9:40pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
You can knock all the interior lights off by holding in the lights button beside the interior mirror for about 10 seconds. To resurrect them just press the switch again. Saves running down the battery when working on the car 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #699821 9th Sep 2024 12:29pm
tspd
Great tip, thanks L322 2007 S/C 4.2L (first full fat)
Buckingham Blue
Post #699823 9th Sep 2024 12:32pm
