Home > Technical (L322) > No Indicators
mercs600
England 2002 Range Rover Vogue Td6 Java Black
No Indicators
Just got in the car to go out for a meal and first off I cannot get the stereo/screen to turn on and then whilst driving without it find out the indicators are not working Shocked
Therefore drove it straight home and checked everything - nothing obvious - disconnected and reconnected the battery - still same ! When pressing the alarm to lock the car the indicators flash so I know they are all right Confused
Unsure of where to go next Confused Havent touched anything electrical etc today and it was all working fine this morning Confused
Any help would be gratefully recieved.
Post #69961 25th Jun 2011 7:42pm
cant really think what it could be ..thought of fuses but cant find anything on rave..
is the battery up to the job, maybe low voltage is causing these problems..
Post #69966 25th Jun 2011 8:01pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I've had this problem 4 times in 20k miles over the last last year. No apparent reason, no faults on the test book, after 30mins or so and I threaten it with open wallet surgery it decides to work again on its own. Laughing 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #69967 25th Jun 2011 8:05pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
A car that fixes itself? I want one of them! Laughing
Post #69970 25th Jun 2011 8:45pm
Jonno
Problem is it won't stay broke long enough for me to fix it! Rolling with laughter 5.0 supercharged autobiography
Post #69972 25th Jun 2011 8:55pm
I've had this. Pull fuse 49 and leave for 5 mins. Thumbs Up Mine did this the day I picked it up. Had no interior indication of indacators, fogs front an rear, nav screen (had power as it opened for the tape) and no parking sensors unless I pressed the button. Pulled all the fues's etc but never left them out long enough.
Post #69979 25th Jun 2011 10:37pm
mercs600
Thanks for the tips - what I did was earlier in the day I had a look in the rear compartment as the CD output was crackling and popping so I thought I would have a look to see if there was any water ingress.This involved moving some wires - but not disconnecting though - and all is dry in the back.Put the cover on and then the next time I started I had these problems ! So returned to the back and just moved afor mentioned wires and now everything back to normal ! Can't seem to see how the indicators could be linked to the screen though Confused
Anyway - fingers crossed it will all be ok now but if it doesn't I will try the fuse 49 trick Thumbs Up
Post #69998 26th Jun 2011 9:38am
Never mess with a working Range Rover Laughing
Post #70000 26th Jun 2011 10:05am
