Home > Maintenance & Mods (L405) > Fuel tank guard replacement.
When I replaced the ARC/ACE pipes, it was pretty obvious that the original fuel tank guard made from mild steel and barely painted, was near the end of it's life. It had several holes and was rusty just about everywhere...
I sourced a second hand one and had it sandblasted and hot dip galvanised.
When I dropped the rear subframe to do the pipes I couldn't get the prop off the rear diff so unbolted it from the transfer box and dropped it with the rear subframe.
I never looked to see if it was possible to change the fuel guard, which involves removing the whole tank, with the prop undone from the transfer box only, or does it require the prop to be totally removed from the diff....
Any advice from anyone who has changed the guard, or tips on getting the prop off the diff, gratefully received.
We tried to undo the nut holding it to the rear prop with two large adjustable spanners and two 4ft scaffold poles, we gave it some serious pressure but it felt like something would break...
Cheers...
 Pete
-Click here for Thread-
Post #699688 7th Sep 2024 3:02pm
fisha
My gut feel is that the prop will need to be off. Look at this pic from the lads on here doing the ace pipes. The tank still has to drop lower to clear the chassis and it’s already looking like it’s at an angle that the prop would be blocking it as I don’t think there is much flex at the diff end.
For doing my pipes I bought a 52mm spanner from Amazonbut didn’t need it. Might be stronger than an adjustable. Wasn’t the worst of prices either.
It’s a 52 and a 36mm you need apparently. I’ll double check later if the 52mm one fits if you want.
My tank guard is rusted badly too … but I just left it ! V8 or else ...
Post #699691 7th Sep 2024 4:26pm
knwatkins
I took my rear prop off when I did the my diff pinion seal which was weeping. You need to use a 36mm spanner on the prop side. I have the JLR special tool set for the rear diff and I'd be more than happy to post the spanner to you if you would like to borrow it Pete.
This is the set. As you can see, the spanner has little ears on it to grip the nut.
Also, make sure you are turning it the correct way. See here...
&t=135s Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #699729 7th Sep 2024 9:40pm
that fuel tank is a lovely bit of work Thumbs Up ... - .- -.
Post #699730 7th Sep 2024 9:58pm
Fisha, thanks for the info, I'll borrow Kev's spanners, that should sort it... Thumbs Up
Kev, yes please incoming PM.... Thumbs Up
Stan, it does look a bit blingy, should last about 30years.... Thumbs Up Pete
Post #699732 7th Sep 2024 10:22pm
NoHandSignals
United States 2016 Range Rover 5.0 SC V8 Aruba
Definitely got to undo both ends of the prop, I would say. I thought one end might work at first myself when I changed my tank shield, but couldn’t figure it out. Note I did remove and replace the shield without dropping the tank though - see my earlier post on this.
Here are the tools that I used to undo the propshaft at the differential end. A 36mm and an adjustable wrench from Amazon (couldn’t find a 52 or 52.6mm at a reasonable price). Together with two 3ft long pipes from Menards (one an inch diameter, and one an inch and a quarter diameter) to fit nicely onto each wrench and extend it for leverage.
Had the Range Rover a couple feet of the ground on a ramp, and had the 36mm wrench/pipe on the propshaft and also up against the ramp so that it could not rotate, and then had both arms free to pull together on the 52.6mm set adjustable wrench and pipe that was on the flange.
GEDORE - 6576700 894 36 Single... https://www.amazon.com/dp/B018CQJGCQ?ref=ppx_pop_mob_ap_share
Lichamp 12-Inch Wide Jaw... https://www.amazon.com/dp/B089T71V7M?ref=ppx_pop_mob_ap_share
Post #699741 8th Sep 2024 3:34am
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Psyching myself up to do this job and one of my concerns is removing the propshaft. The above info is invaluable.
I might be next in line to borrow the spanner or being an old school meanie I might spend the next fortnight making one.
Thanks for the info.
Pete
Post #699749 8th Sep 2024 9:13am
NHS, Thanks for the information, most helpful... Bow down
Pete, if you make one, the "little ears" in the set above look like an excellent idea.... Thumbs Up Pete
Post #699764 8th Sep 2024 11:40am
NoHandSignals
Those “little ears” do look like a good idea, think I recall reading somewhere though that those “little ears” need removing for some reason on later vehicles, and that the newer version of that wrench does not have them? Easily done with a hand grinder I suppose if it proves necessary.
Post #699775 8th Sep 2024 1:48pm
fisha
If you search the tool part number you can find a pdf with the technical drawing of it and it shows where the teeth need filed off. V8 or else ...
Post #699790 8th Sep 2024 6:31pm
fisha
Just to confirm, 52mm spanner fits snugly on the prop …
 V8 or else ...
Post #699819 9th Sep 2024 12:01pm
Thanks for checking... Thumbs Up Bow down Pete
Post #699825 9th Sep 2024 12:59pm
Spridget
NoHandSignals.
Did you use new bolts on the front end of the prop?
Pete
Post #699860 10th Sep 2024 9:02am
NoHandSignals
Yep, sure did. Definitely a good idea to have a fresh head for tool fitment, and they came with the locking compound already fitted.
Can’t recall exactly but I don’t think they cost too much, a couple dollars each? Mail ordered in advance from LandLeaping, together with a lot of other new bolts for the tank shield fixing. Unlike the prop fixings, I don’t think that’s strictly necessary, just with the age of the car anywhere a bolt attached into the aluminum body I generally placed a new bolt in order to have a fresh zinc coating.
Also, while I remember, I marked that end of the propshaft with a dab of paint on both the gearbox and prop flanges to make sure I reassembled to the same alignment. Not sure if this was necessary but seemed to make sense in case of any factory balancing.
Post #699873 10th Sep 2024 10:58am
NoHandSignals
Nice, likely much better than the adjustable wrench I used, and I’m sure just as affordable!
Post #699874 10th Sep 2024 11:29am
