Home > Technical (L322) > Testing parking sensor resistance in situ?
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
My PDC isn’t working. I’ve replaced the module with a second hand one which works for a second then stops.
I’ve read that a single duff sensor turns the whole system off (so listening for a ticking sound at each sensor wouldn’t then work?).
I’d rather check resistance from the PDC end of the loom.
Does anyone have a wiring diagram for the plugs that go into the PDC please?
Post #699689 7th Sep 2024 4:19pm
NDT
Incidentally there’s no sign of water ingress inside the old module.
Post #699690 7th Sep 2024 4:25pm
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
Can't really help you with a value but I'd pop them out and measure them all. If one's at fault you're most likely to find it.
I think a GAP tool can tell you which one if you have the tool.
Post #699794 8th Sep 2024 7:46pm
