![]() | Home > Maintenance & Mods (L405) > Filling / bleeding the coolant ... how to you manage it ? |
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 203 ![]() ![]() ![]() |
I was only reading about this a couple of hours ago. Seems to me you need to remove the rear wheel arch liner and disconnect pipes there. Of course I stand to be corrected 👍
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
MD's fill the system with a vacuum tool. Just had my coolant changed due to replacement gasket and there was very little fuss involved. Simple drain and suck fill. No rear pipes or wheel arches out. 405 AB exec seats Baltic and Cirrus
Mmmm as said stood to be corrected. Seems I misunderstood the rear was for drainage and flushing. Sorry.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1504 ![]() ![]() |
I’ll re-read the WSM and see how it goes. I cracked open one of the joins in the wheel arch and coolant came out … so the coolant is getting to there along one of the pipes. (I’m wondering whether there is a valve in the rear unit which is not letting the coolant flow through.
So had another stab at it this morning. ( I'll add pics a little later )
Sounds like a pain in the buttocks. I had issues with mine a couple of weeks ago. It’s cold in the rear,but the heaters work great front and rear passenger compartment. So as the pooch is always in the back it’s better for him for now.
Just one of those things that you reach a point where you go sod it, I'll just have at it and accept I'm going to get wet. Much muttering was had thats for sure ! |
