![]() | Home > Maintenance & Mods (L322) > Used oil analysis, 4.4TDV8, 25859km. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3380 ![]() ![]() ![]() |
As your car has a DPF why have you chosen a Mid-SAPS C2/3 oil? Everyone uses C1 on these engines and reports of engine failure are so rare as to be not worth worrying about. The wider the viscosity range also means the more the oil will shear so you may end up with a 0w-20 oil at the next analysis..... 2012 TDV8 Vogue (L322) |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701 ![]() ![]() ![]() |
On the oil front, I think most people who use Shell, including me, are using Shell AJ-L 5w30 C1 which is slightly different to what you are using. Whether it has any difference I don’t know.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850 ![]() ![]() |
It’s not just the engine oil that needs to warm up…
I believe the engine revs are higher / gears held longer during warmup to ensure enough oil flow with the thicker oil. This will be governed by engine temps ( maybe oil temp) and I can't think how the engine would know what the oil viscosity is? 2012 TDV8 Vogue (L322) |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1433 ![]() ![]() |
c1 is low saps, ash content 0.5% where c2 is mid saps, 0.8% ash. in a nutshell c2 has 60% more ash in it than c1 ![]() |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 128 ![]() ![]() ![]() |
What's the only way for 'oil' to reach the DPF?
Oil is continualy burnt in the engine from the turbo seals and not just the valve seals and how do you know how much SAPS % it takes to create ash? Just because your oil level doesn't go down doesn't mean the engine is not using oil as it's being topped up by fuel |
Right, the turbos, I forgot about those.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1554 ![]() ![]() |
I don't understand that idea/notion. The regen process is generally accepted to end up with fuel seeping past the pistons and into the engine oil. Once the fuel is in the oil and diluting it ... it stays there, no matter how much driving you do after the regen. That dilution value will only then increase each time you do a regen. I cant think how the dilution value would ever go down. V8 or else ... |
Diesel fuel will evaporate, less fast than petrol, but still. There are volatile parts in (even fresh!) engine oil too. How much is measured and it's call the NOACK value. https://en.wikipedia.org/wiki/Noack_volatility_test Even when oil sump temps will never reach 250C, some engine parts will certainly get very hot, hotter than the sump oil and they are cooled by oil. If you think the crank case is a closed environment: remember the crank case ventilation. So volatile components will and do have a chance to get out of the oil, especially during longer drives. 2012 4.4TDV8 2000 Honda S2000 |
If you have fuel dilution in a diesel engine, it wont all magically burn away, if any, no matter how hard you work the engine.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1015 ![]() ![]() ![]() |
This is so true, a friend of mine by mistake put in Mannol C3 oil in his 2012 4.4 TDV8 and within eight weeks he had DPF Full messages ( amber warnings ) on the dash, C1 is the better oil because ash is the enemy ! |
Unlikley and unproven. Even if the surface temp of some internal component is higher than the overall oil temp all the oil would need to be that temp for any fuel to evaporate off. 2012 TDV8 Vogue (L322) |
