Home > In Car Electronics (L322) > Help disconnected optical now no sound no aux
Lefty84
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Java Black
Hi. I disconnected the optical cable entering the Bluetooth module.
I tried bypassing it with a bit of tube just to see if the radio would stop resetting itself. It didn’t seem to do anything and all I had was the Land Rover screen. Then I put it back together and now I have no sound
Not only do I have no sound from the radio option but I can no longer select CD, DVD or Aux.
Do I have to reset it? Is there something I’m missing here because I thought it would all turn on as normal.
Post #700364 18th Sep 2024 11:39pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
i had that problem, did what you have done and its been fine for several years now
although the cd stacker packed up some time ago RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #700367 19th Sep 2024 4:06am
Lefty84
Is there a reset?
The screen beeps and the reverse camera works.
Post #700373 19th Sep 2024 8:43am
Lefty84
Also, is this supposed to be connected to something?
Post #700374 19th Sep 2024 9:00am
Lefty84
Post #700379 19th Sep 2024 10:05am
knares
no idea what that is, is that in the rear left side RR 2005 4.4 petrol
Post #700397 19th Sep 2024 1:53pm
Lefty84
Yes. I didn’t unplug it and I can’t see where it goes. I have a feeling it’s factory and for a piece of equipment that’s not on a 2006 vogue se.
Post #700400 19th Sep 2024 3:16pm
pcourtney
using a factory made Car Fiber Optic Loop Connector MOST Network fits AUDI BMW MERCEDES PORSCHE would be useful, you can then test one piece of equipment at a time, could be the Bluetooth module at fault, could be something else
https://www.ebay.co.uk/itm/124977129624
Post #700403 19th Sep 2024 3:31pm
Lefty84
I picked up a bypass for the most.
I’ve unplugged the power connector to the Bluetooth and bypassed the fibre optic.
Still no sound.
What is the minimum the system needs to run?
Head unit, controller in dash but in the rear of the car what is essential? If I bypass everything except the amp should I expect it to work?
Could I have damaged the fibre optic cable?
I had sound, it all worked but the head unit kept restarting. So pulled the fibre optic but putting it back I have no sound and the head unit still resets.
Post #700520 20th Sep 2024 8:29pm
pcourtney
I think it would be wise to test one device at a time, and see if optic light is on at every point in the chain, something in your fibre connected MOST device chain is playing up
Post #700560 21st Sep 2024 10:39am
knares
is there a plan for the fibre optic.
i would be interested in looking at it RR 2005 4.4 petrol
Post #700562 21st Sep 2024 10:59am
pcourtney
see the graphic above, it goes in a clockwise direction - Device 1 to Device 9 ( the ampflifier) in a fully working MOST fibre ring
Post #700568 21st Sep 2024 12:02pm
Lefty84
I GOT IT WORKING.
Unplugged everything went through the MOST, bypassed everything in turn. Tried the self test.
Nothing worked.
I decided to pull the battery for a few minutes and put it back on and that fixed it.
So I’m back where I started. TV tuner had been ditched out already- that’s what that connector was in the photo I posted above-
So basically like many IT problems it just took turning it off and on again to fix.
I still have the original issue where the head unit restarts every few minutes.
Post #700594 21st Sep 2024 8:27pm
knares
ok thanks
so can any of these things be removed and just bridged, like the CD stacker RR 2005 4.4 petrol
Post #700610 22nd Sep 2024 3:43am
pcourtney
You might have a dirty fibre end connection, which is why the AHU ( Audio Head Unit) keeps resetting itself, try to clean each connection along the route with lint free wipes or some isopropyl alcohol, it must be very clean for the fiber optic light signal to operate correctly along the route.
Post #700627 22nd Sep 2024 9:55am
