Home > Maintenance & Mods (L405) > PAS Fluid
supershuttle
PAS Fluid
Was messing with my car and I noticed that the PAS Fluid was low what do I top it up with nowadays, the book says Texaco Cold Climate PAS Fluid 33270 but I’m not sure that available any more is there an equivalent what do others use? Geoff
Post #700596 21st Sep 2024 9:23pm
Mikey
The 405 has electric power steering, thus no fluid reservoir
Was it the ARC fluid reservoir you've checked?
Post #700597 21st Sep 2024 9:24pm
supershuttle
Probably the book calls it Dynamic Response fluid Geoff
Post #700598 21st Sep 2024 9:29pm
fisha
That reservoir is for the dynamic response active cornering system which contains a hydraulic pump, valveblock, anti-roll bars ... and pipework.
Ordinarily, it shouldn't lose any fluid, and if it does, then the most likely culprit of the loss is corrosion of the pipework, leading to leaks.
That being said, it may just simply be low and needing topped up. Generally, cold climate PAS fluid is what you need. I listed out a few of the common variations near the top of this thread:
https://www.fullfatrr.com/forum/topic65671.html
I think I would top it up first and monitor it. Would also be worth looking on the underside for any wet patches where the pipe work runs. ( For the rear, it runs from underneath the LHS front seat, down the LHS sill and up and over the rear subframe/diff area ).
If you find patches, or it continues to drop ... then start reading the threads about ACE pipes. Whistle V8 or else ...
Post #700606 21st Sep 2024 10:33pm
supershuttle
Thanks mate for the very comprehensive response. I'll top up first as you suggest and go from there with my fingers crossed. I only noticed it when I was under the bonnet for something else, its lower than minimum. For a top up I imagine 1L will do? Geoff
Post #700614 22nd Sep 2024 7:18am
fisha
Yeah, if there is fluid in the reservoir and you're just topping it up, 1 litre would be plenty I would have thought. V8 or else ...
Post #700624 22nd Sep 2024 9:02am
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
Yes. The reservoir holds about 300 ml. The entire system holds about 3 l.
Post #700653 22nd Sep 2024 4:59pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
I'm sure it's 2l. that is what I bought from the LR dealership (on their advice) to do a reservoir/filter replacement and oil change and I used just under the 2l. Often overlooked because it can get a bit messy the reservoirs that contain the filter (from 2015 I think) are supposed to be changed every 5 years or 60,000 miles according to the service manager at the local stealership.
Post #700739 23rd Sep 2024 4:56pm
