![]() | Home > Technical (L322) > Oil level |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850 ![]() ![]() |
Not sure what’s in the picture…but why not add 0.5L and then re-check level ?
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3381 ![]() ![]() ![]() |
The oil level indicator usualy tells you how much to add. Better to put in a bit too much than too little. 2012 TDV8 Vogue (L322) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
Was that with a cold engine or 20min post shut down? When cold, it should read 2 notches above mid way. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
Personally i am in the “better a little under than overfilled” camp… |
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 300 ![]() ![]() ![]() |
Sorry for the late response it’s one notch under halfway. But it would take more than 0.5ltr to bring it back up I’ll give it a go thanks again 👍 |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 70 ![]() ![]() ![]() |
It’s 2 liters between empty and full on dash gauge. So adding 0.5L will get you a 25% increase to 75%, which will be fine. It doesn’t have to be full. |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 128 ![]() ![]() ![]() |
The warning you get from the instrument panel when the oil level reading is over 'Full' is not something to ignore.
