Home > Maintenance & Mods (L405) > Upgraded front calipers.
Page 2 of 3 <123>
Gremlin500
Take out the new bleed nipples now before they go on, and carefully wrap just the threads in PTFE tape to act as an electrolytic barrier, you or someone may be grateful one day….
Don’t forget to put aluminium anti-seize on the ends of the pins, and top/bottom edges of the pads.
Great fun installing these, pics please Kungfupanda! Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #700776 24th Sep 2024 12:58pm
kevinp
WOW! They look super smooth.
Post #700784 24th Sep 2024 2:27pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
kungfupanda wrote:
Just got the calipers back from the refurb company. I’m over the moon with them. Pistons were fine, they just fitted new rubber boots and bleed nipples.
Company are called Brake Caliper Refurbs based in Rochdale.
They look great! Do you mind me asking how much the refurb cost?
Post #700787 24th Sep 2024 3:35pm
Very bling, looks to be a top job... Thumbs Up Pete
-Click here for Thread-
Post #700789 24th Sep 2024 4:13pm
Gremlin500
@hmallet, if it will help, I got these.:
https://www.ebay.co.uk/itm/405039423774?mk...media=COPY
and these:
https://www.ebay.co.uk/itm/264868412222?mk...media=COPY
everything was spot on, except the brakes guys initially gave me the wrong rear brackets and handbrake actuators, but quickly replaced them, no quibbles. On 2 years now, OEM JLR brakes have been perfect. Discs/pads also excellent.
I also replaced sensor wires and all 4 flexibles while I was in there, may as well!
Bleeding the whole system was a b*tch, you need to run the ABS pump. V6 Vogue - “Less is More” - less to go wrong!
Post #700790 24th Sep 2024 4:21pm
kungfupanda
United Kingdom 2014 Range Rover Vogue SE TDV6 Mariana Black
They cost £270 plus an extra £20 for new rubber seals all round because mine were sagging a bit. The pistons were in good shape otherwise it would have been an extra £10-£14 per piston. This is a full strip down, paint and rebuild. I could afford to have them off the car as these are going to replace existing calipers.
Post #700795 24th Sep 2024 5:05pm
JamboM3
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Indus Silver
Glad you decided to refurb them. I bought some from an eBay company selling them as refurbished and the quality was abysmal. Initially this was down to the logo/decal placement so I whipped out my wheel to remove (ordered replacements) and the powder coat disentegrated. I got BCR to refurb them and the result was it required a complete strip back and found sand in pistons etc..
BCR look like they have done a cracking job there again!
Post #700897 26th Sep 2024 1:51pm
kungfupanda
Yes I’m glad I went for a full refurb too. The lads at BRC are brilliant. Mine weren’t in that bad condition in the first place. They came off a late SVR. I only got charged an extra £20 for new rubber seals all round. I couldn’t buy them for that price!
Just dropped them off for a ceramic coating before they go on. Overkill maybe but I love the way they look and want to keep it that way.
Post #700913 26th Sep 2024 8:30pm
JamboM3
Absolutely worth it, I put 3 coats on mine before fitting. Cleaning was a breeze
Post #700919 26th Sep 2024 11:32pm
kungfupanda
Managed to fit these this afternoon at my mate’s garage. Took just over an hour including bleeding the brake fluid through. However this was with the benefit of having the use of an MOT ramp, all tools I needed on hand and a professional mechanic to call on if I got stuck.
All went well. No seized bolts or scraped knuckles.
Happy with the results.
Post #701165 30th Sep 2024 5:27pm
very nice , but, wouldn't 'range rover' on the calipers be more appropriate.. ... - .- -.
Post #701176 30th Sep 2024 9:05pm
kungfupanda
Thanks Stan. I didn’t really think about the text really. I just went with Land Rover because that’s what all the other post 2018 calipers had on them.
Post #701201 1st Oct 2024 8:00am
Gremlin500
@kungfupanda: so you’re not going to paint the rears to match? Whistle
[img]https://www.fullfatrr.com/gallery/albums/userpics/24757/IMG_0518.jpeg[/img] V6 Vogue - “Less is More” - less to go wrong!
Post #701228 1st Oct 2024 1:13pm
caymanblack
They look fantastic great job. overfinch modified
Post #701235 1st Oct 2024 3:05pm
kungfupanda
@Gremlin500, yes of course I’m going to do the rears! Just feeling a bit under the weather at the moment so taking my time. Might just get a mobile outfit out to do it.
Post #701241 1st Oct 2024 4:35pm
Page 2 of 3 <123>
