Home > Technical (L405) > Should I be worried about my gearbox?
peekay
2016 Range Rover Autobiography SDV8 Corris Grey
Also having an issue with the gearbox, was very intermittent but getting more regular. When I start car in the morning, select reverse or drive, when I pull away it seems to need to rev very highly to get car to move. Almost like clutch slipping. However if I select park/neutral then go back to the selected gear everything is fine. Car has 60k, 66 plate. Have recently had gearbox oil and filters changed (5k ago). Any ideas ? Thanks in advance
Post #691217 24th Apr 2024 4:03pm
peekay
Just a bump on this in case anyone has any ideas
Post #700861 25th Sep 2024 7:28pm
knwatkins
That's normal. From cold, the vehicle will hold onto the lower gears for longer. This is purposely to raise the temperature in a shorter amount of time. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #700872 25th Sep 2024 10:16pm
cass
If it didn’t do it before the oil change then it could be worth checking if the fluid level is correct, it’s easy to under fill it. Did it get the correct ZF fluid or a cheap alternative?
Post #700873 26th Sep 2024 3:33am
