![]() | Home > Technical (L405) > No headlight main beams |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1090 ![]() ![]() ![]() |
I’d be interested to see the responses. My new car, a 2021 MY P525 has the same light set up and whilst I’ve yet to drive it in the dark, it seems odd to me that I can’t keep the headlight switch in the on position, as I discovered when I wanted to switch the headlights on in low light conditions during a recent journey in pouring rain. |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1417 ![]() ![]() |
Does your code reader also clear DTC's? If it does not, get a cheap Autel AP200 or similar, clear all codes and see if it fixes the problem or if it returns.
I always keep mine in the Auto position, it comes on during low light conditions! Adaptive lights are amazing. Look also at the related information tab. https://www.ownerinfo.landrover.com/docume...1/G2418244 2018 SE SDV8 4.4 Byron Blue |
firstrr Member Since: 27 Sep 2024 Location: Lancashire Posts: 36 ![]() ![]() ![]() |
Thanks Kot. Yes I’ve cleared the dtcs and the problem remains, no main beams although the blue dash light comes on when operating the stalk. It was a long shot but I thought that neither beam coming on might have been a quick fix from a members previous experience. I’ll have to work through the checklists when I get chance. Thanks again. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
result ! |
go_ko4 Member Since: 06 Nov 2024 Location: CH Posts: 4 ![]() ![]() |
welll. Wow! Thx a lot for sharing - I got Velar with the same "stuck or low problem" on both high beams with the same symptomatic. But in my case one of the headlights is 20MY and other 18MY I thought that this was the problem while the firmware gateway fault. Now I will check for harness more detailed. So as I catch - Your highbeams now works fine? Can You pls upd me what color or nr. of the wire set this problem*
It was the brown wire - high beam signal wire - to the back of the connector of the passenger side headlight unit. See my pic of the broken wire.
Just to clarify, this one broken wire caused both main beams to be inoperative even though the blue light came on the instrument cluster indicating that they were on.
In Your way its passenger side - in my its driver like EU version (: - the left one* well I catch that it was damaged and replaced to the used headlight - but all the wires looks ok except few - moving inside the plug in the range of +/- 2 mm I don`t think that it is the problem but I would better replace and re-pin whole plug* who knows - maybe it will helps.
as You can see the mistakes are setting on the Gateway Module of BCM... I'm really hope that this is not the data problem and its in the BCM cause its a last control unit where data (signal) is indicates as lost* like no needed parameters to indicate, as OK. |
We need a technical expert member to look at these results for you, it's a bit beyond my experience.
dear chief-commander) I just want to thank You a lot for this topic - just found it inside the left plug under the cover)
Result |
