Home > Maintenance & Mods (L322) > Where to buy bonnet and tailgate lettering?
Scouse Exile
Just clean the recess of the letters as clean as you can before inserting the 3M tape, doesn’t need to be anything special, soap, water and elbow grease should do it.
The tailgate likewise needs to be clean, panel wipe or some sort of grease free cleaner is fine.
Do you have a template to work to?
Jon
Post #701015 28th Sep 2024 3:30pm
RangeRov
Sweden
Yes, I have the template by PowerfulUK, I tried to use mask tape whilst the letters was still on to en ensure I'll add the template at the right place, also took measurements.
I realised I have an unopened botte of Gyeon Q²M Prep, would it work to spray this on the tailgate and wipe off?
https://gyeon.de/GYEON-QM-Prep?srsltid=Afm...F_g2MjRmO5 2009 L322 4.2 Supercharged
Post #701018 28th Sep 2024 4:18pm
Scouse Exile
Yes I think you’ll be fine with that. The 3M tape is pretty sticky and is quite forgiving of a surface that’s not perfectly prepped.
J
Post #701035 28th Sep 2024 8:30pm
RangeRov
Sweden
One done, fingers crossed I'm doing it right!
Post #701074 29th Sep 2024 2:25pm
Scouse Exile
Looks about right to me, just make sure the tape isn’t too high on the areas where it’s hard to create the right profile, like on the round bit of the “R” for example - just makes it sit flat better on the panel.
Jon
Post #701077 29th Sep 2024 3:26pm
RangeRov
Sweden
Final product!
I did remove the letters and added the one by one into the template from PowerfulUk.
I did not use the template tape to get the template on the tailgate rather masking tape to keep it in the right position, then I checked my measurements prior to removal about 3-4 times.
How do you think it went?
Before
After
Post #701084 29th Sep 2024 5:13pm
supershuttle
Here I go again hijacking threads, is it possible to buy a template, the one I made for my l322 is a lot narrower to what I now need for my L405. I made the previous one from Christmas cards and masking tape - but I'd rather not wait until Christmas. I got the letters of another member and prepped them with new sticky tape so they are ready to go on now.. Geoff
Post #701087 29th Sep 2024 5:23pm
Scouse Exile
Looks good to my eye, well done.
Post #701095 29th Sep 2024 7:15pm
toby1
It looks good to me. 2012 Vogue TDV8 in Aintree green over sand
Post #701134 30th Sep 2024 2:18pm
landy95
Nice paint job on the tailgate. How much did that cost. I need to get mine done. Cheers. Also own a 1976 Land Rover 101 3.5 V8.
Previously owned:-
2012 Range Rover Westminster.
1991 Range Rover Vogue 3.9 V8.
Post #701161 30th Sep 2024 4:29pm
Scouse Exile
I suspect the cost of taking it to Sweden might impact the cost consideration a bit Very Happy
Post #701166 30th Sep 2024 5:28pm
landy95
Rolling with laughter I missed that, oops. Also own a 1976 Land Rover 101 3.5 V8.
Previously owned:-
Post #701179 30th Sep 2024 9:07pm
RangeRov
Sweden
The tailgate costed me 515 GBP Smile 2009 L322 4.2 Supercharged
Post #701198 1st Oct 2024 7:22am
