![]() | Home > Maintenance & Mods (L405) > Halogen to Led |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
you said you bought the D1S bulbs chef which are not the correct fitment type..
| chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 766
Thank you Stan |
Update:
My saga continues!! It’s like dip and dazzle, the lights are pointing into the ground just in front of me! Wish I’d left them alone now |
get someone else to fit them chef.. |
Obviously there’s a right and wrong way to fit then Stan? 2014 vogue se |
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1880
Hi Chef, read this thread:
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3394
Did HID to LED on my L322 earlier in the year. First the main beam (which was Halogen) and then the HID dipped. Light output is significantly higher and the dipped beam focus better with a very distinct cutoff but.......for driving in county areas I think they are too bright as reflections off road signs especialy become very dazzling on main beam and it generaly destroys your night vision. I'd say the ideal illumination level is just enough to see the road so it would be great if they could have variable output or simply have lower brightness versions (which I've not investigated) 2012 TDV8 Vogue (L322) |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1560
Every bulb is slightly different in where the light originates from, particularly when you're changing between bulb technologies. Given the small distances within the reflector / projector lens versus the throw of the beam down the road, then even the slightest difference within the bulb/projector setup will translate to a large difference on the cut off on the road. Might be a bit late now, but when changing bulbs, I park about 5m away facing the garage or flat wall, and mark on the wall where the original cut-off lines and the verge up-step of the beam is. Then fit each bulb at a time, an re-adjust the beam to where the marks on the wall were. Its always been a case of having to adjust after fitting ... both vertically and (less so) horizontally. V8 or else ... |
Thank you fisha!
I guess I was lucky in that case.
You can if you want ... but I'm north Ayrshire, so a bit of a trek for a set of bulbs !
i'm surprised that any adjustment would be necessary...mine just replaced the xenons without any problems.
