![]() | Home > Maintenance & Mods (L405) > Start/stop button - just the cover |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 194 ![]() ![]() ![]() |
Sorry, I don't know the answer to your question, but the stop start, and other buttons on mine were in a gooy, sticky mess and after watching a youtube video I was able to clean them Using a Q tip and Isopropyl alcohol. They have a 'soft touch' coating which turns into a sticky mess. The alcohol allows you to carefully peel it off and reveal the hard plastic underneath with symbols still intact.
Dartanjang Member Since: 03 Nov 2022 Location: Vasteras Posts: 17 ![]() ![]() ![]() |
Good suggestion. I will check it out and see if that proves to be satisfactory.
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 164 ![]() ![]() ![]() |
These *may* be the part numbers...
Thanks for the suggestions JD. I checked them out and they seem to be for the entire switch. The search for the cap only continues.
I doubt you will find cap only.
