Home > Maintenance & Mods (L405) > Blue screen of death on reverse camera L405
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Evening All,
After some advice please, I have today driven my L405 2013 which has surround cameras, drop into reverse, no reverse camera (blue screen), all other cameras ok, am I right to assume i need a new camera?
If so how hard are they to change and roughly what cost please?
I will check wiki to see, any thoughts?
DrF
Post #701729 7th Oct 2024 8:32pm
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
If everything else seems OK - I would think it was the camera.
I hope the fix on an L405 is better than the L322 - that was a terrible mess.
Good luck with it. 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #701778 8th Oct 2024 4:01pm
Silverstone
United Kingdom 2016 Range Rover Vogue SE SDV8 Loire Blue
Are the parking sensors working? "There is no replacement for displacement" - W O Bentley
Post #701779 8th Oct 2024 4:03pm
DrF
Thanks CHaps,
Yes parking sensors are working fine, just the blue screen of death on the reverse camera only
DrF
Post #701807 8th Oct 2024 11:55pm
DrF
Right so I now bitten the bullet and have a replacement camera, now my next question is how does one get access to remove the little blighter please?
DrF
Post #702320 16th Oct 2024 9:13pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Here you go, very easy job, just prise the finishing strip away from the tailgate, see the link below:-
https://www.fullfatrr.com/gallery/albums/u...LATION.pdf L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #702322 16th Oct 2024 9:47pm
DrF
Many thanks 4RRS,
I will have a fiddle around tomorrow, wish me luck
Fingers crossed it cures the blue screen of death.
DrF
Post #702324 16th Oct 2024 10:29pm
minim
Norway 2013 Range Rover TDV6 Santorini Black
My camera was full of water/corrosion when this happened. The instructions above doesn't apply for the 360 version BTW. I removed the inner trim and pulled the camera from the inside.
This is how mine was inside.
Post #702325 16th Oct 2024 10:32pm
4RRS
Before you plug the new camera in, just double check they are identical as there are 4 pin and 6 pin connector types, not sure of the model year when they changed. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #702326 16th Oct 2024 10:32pm
DrF
Thanks for the advice, I have been told I need part number 52029 which is a 6 pin, I shall find out tomorrow.
Now here the dilemma, I am pretty sure I have whats called the surround camera system, I have rear camera, wing mirror cameras x2 and front bumper cameras x2 so I assume I need to enter via the inside tailgate panel then?
If so how easy is it to get access that way please?
DrF
Post #702328 16th Oct 2024 11:10pm
4RRS
I have the 360 surround system on both my L405 SVA & L494 and have removed both from the outside as per the document. Give it a go, I'm sure you'll be fine. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #702329 16th Oct 2024 11:14pm
DrF
Perfect sounds like a plan.
DrF
Post #702330 16th Oct 2024 11:21pm
4RRS
6 pin should be correct, just checked and they changed at GA chasis number (2016) to the hi definition camera and before 2013 they were 4 pin with a coax connection, ended up changing those 3 times on the Mrs's Evoque many years ago. Seems they always fail through water ingress. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #702331 16th Oct 2024 11:26pm
DrF
Fingers crossed then, I will report back once done.
Thanks 4RRS
DrF
Post #702333 16th Oct 2024 11:39pm
minim
DrF
Sounds right.
It's easier than accessing from the outside imho. The strip outside you need to be careful with as the plastic get old and brittle. Be gentle where it's really thin so you don't Crack it. I have removed it before when I was spraying my rear door and I'd do it from the inside now that I've tried both ways. You just pop the cover off inside and wiggle loose a module that blocks the camera. Use needle nose pliers to unhook it from the plastic and it's out. Doing the outside route risk damaging your paint and cracking the trim. There is a YouTube video explaining it.
?si=8LcfVKGFGyQw9NKO
Post #702334 16th Oct 2024 11:45pm
