Home > Technical (L405) > GAP IID G3 Throwing Errors
Shadow_Dancer
Hi Guys,
I just bought a GAP IID G3 tool. I start the car after inputting the Ghost 2 sequence and as soon as I connect the G3 tool the dash starts to throw multiple errors like aig bag fault, HDC error and others. Its the same even if I put its in valet mode.
Any advice?
Thanks
Post #701785 8th Oct 2024 4:42pm
Do the errors stop when you remove the IID tool? Got - 2017 SDV8 Autobiography in Loire Blue
Post #701787 8th Oct 2024 5:04pm
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Any chance the ODB port has been switch out? I know that it is possible to change the ODB port, effectively rewire it, and require an adapter to plug into it. It is another security measure that can be implemented. Only came to mind as you say you have a Ghost 2 fitted so unless you had it fitted maybe the previous owner went for extra security? Long shot I know but I cant think of any reason why a GAP tool would do what you are seeing. _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #701788 8th Oct 2024 5:08pm
Shadow_Dancer
First time the whole Speedo cluster just went black. I had to switch the car off and wait a few secs to turn back on and it came back but with a bunch of errors. I removed the gap tool and turned it off and on, entered ghost sequence and it returned to normal except engine management light stayed on. Tried again and as soon as I entered the tool it threw more errors but didn’t turn off the screen this time but car would not start.
Post #701804 8th Oct 2024 11:08pm
Shadow_Dancer
It’s possible based on how the car is reacting when I put the tool in the port. However a garage recently plugged in their diagnostic tool and it worked fine. If there was some kind of switch out would their one not have worked also?
I emailed GAP but their responses are pretty terrible. Mostly one liners and not very helpful. See one below
“its either defective or the OBD pins are not tight enough even if they look tight”
Post #701805 8th Oct 2024 11:16pm
Kot
Get a Autel AP200 they are good and cheap and will certainly be proof that the GAP tool is ill or not. 2018 SE SDV8 4.4 Byron Blue
Post #701811 9th Oct 2024 8:45am
Shadow_Dancer
Thank you Kot, I’ll give that a go
Post #701812 9th Oct 2024 8:48am
Kot
Dont buy from amazon/fleabay
https://www.autelstore.co.uk/wholesale/aut...anner.html 2018 SE SDV8 4.4 Byron Blue
Post #701814 9th Oct 2024 8:53am
Shadow_Dancer
Post #701816 9th Oct 2024 9:08am
I always plug mine in with the ignition off Got - 2017 SDV8 Autobiography in Loire Blue
Post #701826 9th Oct 2024 11:56am
Kot
I do also, then ignition on, but engine off to do checks. 2018 SE SDV8 4.4 Byron Blue
Post #701827 9th Oct 2024 12:43pm
i fear this 'might' be user error....
was the gap iidtool inserted properly? if some pins were bent then this would certainly cause problems.. ... - .- -.
Post #701828 9th Oct 2024 1:13pm
Shadow_Dancer
all the pins on the gap iid tool are dead straight. I have tried to re-insert multiple times. I tried inserting with car fully off and search but would not detect tool.
I tried with power on but engine off and still does not detect tool.
As soon as I turn engine on and search for the tool it throws all the errors.
Post #701829 9th Oct 2024 1:17pm
can you try the tool on another landrover vehicle?
this should confirm whether the tool is at fault . ... - .- -.
Post #701830 9th Oct 2024 1:19pm
Mikey
We see this on occasion. Dash lights up like a Christmas tree when you plug the tool in
Very rare that it does happen, but we can't get the tool to work at all when it does, and grab the next bit of kit
Post #701832 9th Oct 2024 2:19pm
