Home > Technical (L322) > Folks with ACC - Seeking guidance
loudog3114
United States
I am working on retrofitting ACC to my 2011 NA 5.0 HSE and I have run into an issue nobody else so far has. I fitted the radar module, the steering wheel switches, and then made all the ccf changes with iidtool but I am getting an error "C1A67-87 - Forward Looking Sensor - Bus signal/message failure - missing a message (2A)."
I'm trying to figure out if the radar module I got is bad or if I am just missing a module altogether. I see two options. AH42-14B588-AA or LR025949 (maybe they're the same?). The former option is only $28 on eBay vs $180.
Some folks report there is that module in the compartment over the rear right wheel (if facing forward at the back of the car). Can anyone with a 5.0 with acc take a peak back there for me and tell me if you've got more back there than I have?
Post #700753 23rd Sep 2024 10:23pm
georgekale
United States 2011 Range Rover Supercharged 5.0 SC V8 Baltic Blue
Front radar sensor in front bumper. Then you need to aim and reprogram
Post #702016 11th Oct 2024 6:47pm
georgekale
I had the same problem. first radar module did not work. I replaced it with one shown and worked.
Good luck.
Post #702017 11th Oct 2024 6:56pm
loudog3114
United States
Yep that was my issue. $200 down the drain.
Post #702018 11th Oct 2024 7:09pm
toronnoRR
Canada
How much did this whole project cost you? I would love to add this if it isn't too expensive
Post #702379 17th Oct 2024 2:30pm
loudog3114
United States
With the $550 Iidtool I think it was $1300ish. Worth every cent.
Post #702385 17th Oct 2024 3:55pm
